Question about Motorola Mobility RAZR V3
V3 Razr I have a V3 Razr I bought off of ebay about a month ago. It will not take a charge. Put a new fresh fully charged battery in it and it drained it quickly and will not charge. My carrier has resync'd it a couple of times and replaced the sims card (which was very nice of them) but that has not helped. It now turns its self on and off, if you are able to get a charge to it at all.
  • jeffy139 Dec 07, 2008
    my razr will not take a charge I have replaced 3 times with verizon and they keep doing the same thing after 3 or 4 months driving me nuts
  • Matthew Moore
    Matthew Moore Dec 07, 2008
    my v3i will take a complete charge stay on for about an hour or so then the battery just goes down.
    Sergeant:
  • 274 Answers
It's the phone itself that needs to be fixed. Buyer beware as they say about Ebay. There are cheap repair shops around depending on where you live. No more than $50. Might have to call around to fid one.
Posted on Aug 19, 2007
SOURCE:
My razr v3 died yesterday. tried all night charging, still dead. no juice to turn on. bought 2 years ago, worth new battery?
Well... I would say no.. Not worth battery.. I had the same thing happen to me where my phone wouldn't charge and we bought a new battery for $50.00 and then we find out my phone is shot.. so I would strongly recommend getting a new phone..
Oct 09, 2009 | Motorola Mobility RAZR V3
New phone put to charge but charge light goes on
battery may be faulty or the software needs to be reload
Jul 06, 2009 | Motorola Mobility RAZR V3
Razor v3 wont charge is there anyway to fix the problem
Hi
It seems like you need a new battery, you can get a replacement one for cheap on Ebay.
David
CellUnlock.net
Feb 26, 2009 | Motorola Mobility RAZR V3
Invalid Battery
Totally discharging the battery is the way to go. But what you can also do to use your phone in the meantime is this. Plug your charger into the phone withOUT your battery in. It will tell you "Unable to Charge." When it says this, put the battery in. It might tell you "Invalid Battery" a couple more times, but it did eventually say "Charging Battery" for me. After that, simply turn the phone on and it will return to normal. This is when you drain the battery completely. Once I did that, I did not get the invalid battery error again.
May 14, 2008 | Motorola Mobility RAZR V3
Moto Razr v3
If theres no problem with your phone charging on its original battery before you replace it. the problem lies with the new battery you purchase, just replace it, coz some batteries are due to factory defects.
Feb 15, 2008 | Motorola Mobility RAZR V3
New phone razr v3i charging issue
Have to phone sent in for warranty and request a "loaner phone"... sounds like the power drain is too high on the device and it needs service or replacement... another sign would be the unit heating up hotter than normal - is that happeneing?
Feb 08, 2008 | Motorola Mobility RAZR V3
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Dying battery
first fully discharge the battery then place it in a plastic container and put it on the freezer overnight, just make sure that no moisture will enter on the cointainer. after taking it out on the freezer let stay at room temperature for 5 minutes, then charge it. I always do this with my old batteries and it works well.
Sep 26, 2007 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
Replaced Battery - Indicator Doesn't Work
probably the battery is not original and the phone does not reconize'it try buy an original one
Oct 27, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
95 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
