Question about Hoover Company Wind Tunnel U53019 Upright Vacuum
Hoover Wind Tunnel
Both of my belts work, however, it seems the roller won't roll. I have the switch turned to carpet and both belts are running, but burning while running because the roller doesn't want to roll. When we took it apart, we put it back together and when we put it back in, the end seems to screw off the roller when in motion - I was sure we put it back the way we took it out. We even checked the ball bearings and cleaned everything real well. Are we missing a part? Can you please explain to us how to put the roller back together correctly so we can get it to stay in place without unscrewing? Thank you!
  • 625 Answers
What probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Posted on Sep 22, 2007
Brush not turning on my Hoover wind tunnel UH71214.
If you have a two speed roller (floor and carpet position on the switch) the power supply board has blown roller resistance.
Feb 16, 2015 | Hoover Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hoover wind tunnel, brushes are not spinning. Belt seems loose but maybe that is normal.
The belt (one around the roller) will only engage the roller upon 2 conditions. the carpet switch needs to be in carpet and the machine needs to be tilted back. The other belt, may appear to be on, but can be stretched and also cause this issue, the recommended time to replace the belts are 9 - 12 months under normal use.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 24, 2009 | Vacuums
Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Apr 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
Mar 09, 2008 | Vacuums
Edge of carpet went into carpet; was removed, but now all rollers on the unerside don't function.
You didn;'t say what the problem is, but I assume that the brush roll is not turning. Take of the cover over the brush roll, then you can get to the brush roll and the belt. The belt probably came off or broke. Best to replace the belt.
Jan 07, 2008 | Vacuums
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Hoover Company Wind Tunnel U53019 Upright Vacuum Logo
187 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
