Question about Gaggia MDF Electric Burr Grinder
The top canister is supposed to rotate to adjust the grind, but it has locked and won't turn. Is there a catch I need to find?...or, a simple way to disassemble it?
  • Anonymous Nov 26, 2007
    I have the same issue
  • Anonymous Jun 05, 2008
    Gaggia can cover not opening. It has a push switch . Model No. Lama, 230-240V 50Hz 100W No.1107018716.
    I am in India. This is a new unit. Not yet been used. Iam unable to open the cover. Please help.
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Posted on Dec 13, 2008
Take it all apart. You will find the big brass screw is full of fine ground coffee. Clean it carefully and put back together. I had this problem a year ago and cleaned it and added new burrs. Works like new!
Posted on Dec 31, 2008
Did you try turning it while the motor is running?
Posted on Feb 10, 2008
I just disassembled and cleaned my Gaggia coffee grinder. When I turned it on to calibrate the burr plates it made a short grinding sound then stopped and now won't turn on
Take it apart again and check all the connections and switches, security shut-offs, and THE THERMAL SWITCH. A very small and cheap electronic device that takes and overload and will shut your system down, whatever it is. Very easy and quick to replace.
Nov 25, 2014 | Gaggia MDF Electric Burr Grinder
Need operating & maintenance manual for brevetti gaggia mdf burr grinder.
Hello, your instruction manual can be found on this link by clicking or copy and pasteing it to your browser http://www.gaggia.com/dam/bo/allegati/files/31_mdf.pdf if you are unable to obtain these instructions by copy and pasteing to your browser please message me back and I will provide my email so that I may send you them directly.
Thank you
Rick
Nov 08, 2011 | Gaggia MDF Electric Burr Grinder
I have a Gaggia burr grinder, Brevetti Gaggia SA Model MDF, s/n 7262. The handle that you flick back and forth to let the grinds come out broke off inside the unit.fixable? 707=837-8916 Thanks Anne
Look inside the grinder, The lever is attach to a SPRING .
May be the lever is disconnected (unhooked) from the spring.
AND YES IS FIXABLE.
It cost you about $15-$30 for the parts.
Jan 15, 2011 | Gaggia MDF Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
How do you adjust the size of grind with a gaggia grinder
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
Apr 20, 2010 | Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
Grinder is slipping.
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Aug 02, 2008 | Gaggia MDF Coffee Grinder
Can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Jul 12, 2008 | Gaggia MDF Coffee Grinder
MDF very coarse grind
Several possibilities loom:
1. Same burrs for 25 years? don't be cheap replace them!
2. Dirt in the threads of the burr carrier, or the threads that recieve it?
Let us know what works
Dec 18, 2007 | Gaggia MDF Electric Burr Grinder
How long should it take gaggia mdf to grind?
I'm not familiar with this exact model but the problem may be either packing in the unit...since it never worked...or that the beans have jammed the unit in such a way that none are feeding to the burr. Usually, there is a way to remove the top half of the burr after removing the beans. Brush out the area and reinstall. The instructions that came with the unit should be of value. By the way, on some of these units, if the cup isn't correctly placed, it may prevent the burr from receiving flow. Enjoy!
Nov 29, 2007 | Gaggia MDF Electric Burr Grinder
Gaggia MDF Electric Burr Grinder Logo
592 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
