Ecoquest Fresh Air Living Air Purifier
Problem for Ecoquest Fresh Air Living Air Purifier
I have a fresh air by Ecoquest the motor stops
By bags46 on Mar 22, 2009
Ihave a fresh air by Ecoquest the motor stops running for a few seconds then starts again. Has anybody else experienced this.Also looking for a dealer in Riverside County California
Solution #1
posted on Apr 04, 2009
Not Rated)
gototech
Rank: Wiz
Rating: 91%, 25 votes
I recently fixed one with the same problem. Remove the rear cover where the switch is mounted. (Take off the filter first) The wires have enough length that it is not necessary to remove them. Use a blow dryer and blow into the opening to remove dust and moisture from the circuit boards. Either one will make it start and stop. Make sure not to get it too hot or too close. Good Luck. I can't help you with the dealer question as I'm in NC.
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Living Air
Questions and Unsolved Problems for Ecoquest Fresh Air Living Air
Do you recommend Ecoquest Fresh Air Living Air Purifier?
Answer
Answer
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several... (More)
Answer
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine... (More)
Answer
my eco quest fresh air turns on and off continuously
Answer
I have two identical units and I have swapped every removeable/replaceable part including cord and... (More)
Answer
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Fresh Air Living Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2540
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
