Question about Philips 42PF7320A 42 in. Plasma HDTV
Picture and hdmi
My picture is off centre it is about four or five inches to the right and my hdmi dont work is there a way to correct this. thank you
  • 3 Answers
Your gonna kick yourself in the bum. Use your remote left or right button to adjust the center.
Posted on Sep 08, 2007
I cant get any picture on my sony tv when i connect my ps3 upto it, yet get a picture instantly on a cheap 26 inch hd tv. i'm using a hdmi cable on both
Silly question -- but are you sure your Sony TV is on the correct HDMI channel? My 32 inch LCD has HDMI1, HDMI2, HDMI3. You must make sure you plug the PS3 into the correct HDMI channel and make sure you're tuned into the same one.
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
My HDMI ports went out. Everything else works. Can I repair the HDMI ports myself?
Yes you can replace the HDMI ports yourself following the replacement guidelines of the manufacturer, remember to use the same part that was in the first piece of equipment
Nov 30, 2009 | Samsung 61" 1080p Slim-Depth DLP HDTV
Toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Nov 20, 2009 | Toshiba 42HL167 42 in. LCD Television
I have tried to connect my SD 6100 and am getting no picture. I get sound.
You must use the remote to toggle the player OUT of HDMI output mode to use the non-HDMI outputs (like standard RCA-jack VGA or s-video or component video output). The device displays black screen by default unless you're using HDMI, so it's not possible to see the menu if using s-video. The manual states to press the 'Progressive' button to change modes. Unfortunately, you can't see what mode you're toggling through until you hit the right one (Toshiba blew it here!!). Power on the device WITHOUT a disk in (you can't change modes during DVD playback mode). There are four output modes, so press the 'Progressive' button on the remote and wait for 3 to 5 seconds for the player to switch output modes. Repeat this up to four times to cycle through the available modes. During one of the modes, you should see output to your screen through the cable hookup you've physically attached. You will also notice the led's on the front panel go on and off during the process at times. If you ARE using HDMI, then you have to select a mode your TV or monitor can handle. When in HDMI mode, you'll notice the front panel HDMI led's will light up. There are five modes here - 480P, 720P, 1080i, 1080P and AUTO (when all four leds are lit). Select the HDMI mode that your TV works with. Good luck ~ and don't bother calling Toshiba support ... friggin waste of time talking to a recording that's dumber than Sh#@!!
Jul 09, 2009 | Toshiba SD6100 DVD Player
Hello, Greetings from Hamilton Ohio. I have a 54 inch Hitachi rear projection television and I believe the bulb is getting ready to go because it takes about four or five minutes before the picture comes...
Hello
And greetings from York PA!
Ok I have read what you were saying about your TV and after much consideration I dont think its the bulb because a bulb does not get better as it warms up! (most bulbs that are bad get worse as the TV warms up!) But capaciters do act this way when they go bad (stable when they warm up!) so I would have to say the control circut has one or more bad capiciters on it and will need replaced!
I hope this helps greatly!
Please rate this answer!
thank you!
Jan 27, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Four Keys of my Nokia 6680 are not working
Try to replace your keypad with a new one and check, if it fails take your mobile to a service centre for service..also Dont forget to claim warranty..Thank you!..
Jul 22, 2008 | Nokia 6600
Picture doesn't work..Panasonic 47 inch TV PT-47WX42
Dood, if you really needed a new mother board for your TV the biggest problem on your hands would be finding the replacement.  The motherboard is so easy to remove it would make you laugh.  I think it has four clip bridges and four of five screws.  You seperate the clip bridges, take the screws off and maybe take a picture of the cables so you remember where to plug them in and you're done.  Like I said, take a snap shot so you dont forget where to put your cables back in.
Oct 14, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Home theater
The front pannel,on and off channels and vol. switches are going bad,if you dont use the front pannel, unplug the set and remove the back cover,just below the top screws you can look under and see the top of the picture tubes,in front of the middle tube is a little board about two inches wide and four inches long,unplug the right plug it has one black and five or so white wires,this is the top cable,then just use your remote.
Nov 20, 2006 | RCA P60920BL 60" Rear Projection...
Philips 42PF7320A 42 in. Plasma HDTV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
