Question about Sharp EL-2615G Calculator
New ribbon I cannot remember how to put new ribbon on, forgot to pay attention when I took old one of help!
  • 1 more comment
  • josheric Aug 19, 2007
    found manual online
  • jbit Jun 17, 2008
    I couldn't find a free manual so I need instructions on how to load a new ribbon in the EL-2615G.
  • Anonymous Apr 03, 2009
    It would be nice to post where you found the manual explaining how to put in the new ribbon. I've been looking for over 45 minutes with no luck yet.
  • 35 Answers
Find a manual online that explains how to replace the ribbon.
Posted on Aug 27, 2007
  • Anonymous Aug 27, 2007
    oops, just saw your comment. Sorry about that.
SOURCE:
My Name Is Linda Harding my e mail is [email protected] gmail.com My laptop keeps saying wrong password so I can't get on It.
Hi sorry for your loss I want to encourage you I have done that many times change my password then forgot what it was and every time except one I was able to remember it when I was quiet and not stressed. Try this. . . Make sure you write down every password you try so you keep from putting in your answer more than once this will help you keep a log of everything you try pay close attention to upper and lower case letters good luck remember stressing wont help in the very least you will have to reinstall good luck honey and God Bless
Mar 04, 2015 | Computers & Internet
I have a Bissell powerfoforce Bagless. A friend just gave me her older one, she is off to buy a newer model. I have been through every vacuum cleaner you can image, dirtdevil , kirby, etc and on and on. Sh...
There are at least 18 different models of Powerforce. There are too many parts and pieces to be able to describe what you need without seeing it. I suggest paying your local vacuum shop to put it back together. It may need a new belt, brushroll and/or filters. Do scrimp on these things if you want it to work properly.
Mar 14, 2017 | Bissell 6594 PowerForce Bagless Upright...
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
Need to change felt pad on Makita finishing sander model #BO4552
go to Makitausa.com and type in your model number and you can download a schematic for the tool. Let me know if you can't find it or need more help
Aug 08, 2009 | Makita BO4552KR Reconditioned 1/4 Sheet...
How to change the throtle position sensor on 2002 Jeep Grand Cherokee?
this is really easy, when you take the old one off pay attention which way you have to turn it. there is nothing to set, just put the new one on the egsact way you took the old one off. It turns into position, because it turns the throtle body. so it has to turn into position. its really simple, if you have any questions, ask the parts guy to walk you threw it when you buy it.
Mar 21, 2009 | 2002 Jeep Grand Cherokee
How do you replace a fuel injector on a 3.4 V6 in a Chevy Venture?
You will need to remove the fuel rail, pull the injector out and put new one in. Only thing you need to remember is that you have to pay attention to "o" ring seal, making sure you remove the old one and not damage the new one. There are specific instructions for removal in any inexpensive manual.
Mar 19, 2009 | 2000 Chevrolet Venture
Need diagram for how the belts are run on a 1984 GMC Jimmy V6
I did not pay attention  but figured it out the alternator had a dual pully on it and the parts store sold me one with single pully. Took dual pully of old one an put on new one, the rest was easy.
Sep 06, 2008 | 1984 GMC S-15 Jimmy
Ink
hi fushi
puchase a new ribbon cassette (widely available on the internet)when it arrives, lift the printer cover,remove the old cassette (just lifts out ) pay particular attention to where the little piece of exposed ribbon slots into. locate the small exposed piece of ribbon on the new cassette into the slot carefully then click the cassette over the drive cogs (just like playing an old topload video cassette)
Sep 04, 2008 | Epson LX-300 Matrix Printer
How do you open a nuvi 350
Lift the antenna and remove the two screws on the back.Carefully remove the antenna cover and with a small jewellers screwdriver move the left spring loaded hinge of the antenna support toward the centre of the support.Carefully remove the support paying attention to the spring loaded hinge as this will jump out and you are likely to lose the spring or the mobile end.Carefully remove the antenna support extending the ribbon connecting cable so the you can now access the two screws holding the case closed.After removing the screws pry open the case paying attention to the two ribbon cables connecting the display to the main board.Flip the securing flaps on the ribbon connectors and remove the ribbon cables. the unit is now open and you can carry on with whatever you needed to do.
Aug 11, 2008 | Garmin GPS
Sharp EL-2615G Calculator Logo
484 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
