Question about Sony KV-27S10 27" TV
Orion FTDV 2004 Dead Set
Set was Dead after electrial storm. Cable teck repaired cable problem outside home. I opened set up and found 6.5 amp fuse blown in power supply. Replaced fuse, still dead. Reading 119v now thru fuse. No sound no High voltage, no burning. Don't have schematic on Orion set. Is their a place on line to download free schematics or view them?
  • tweety12 Aug 20, 2007
    The set is an Orion,Model: FTDV 2004. It has both the CD and VHS player. Thanks for your input. Keith
    Problem Solver:
  • 18 Answers
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Posted on Aug 19, 2007
  • Donald Block Aug 20, 2007
    Yes at servicemanuals.net
1998 komfort 5th wheel electical problem
i am not certin that i have ever encountered a situation that has 2 outside power input plugs, the situation is that your trailer is wired for a 50 amp service, this service has a plug that has 4 connection points and is set up for a 220 volt supply, the only reason for this situation is that some one modified the power input to your trailer , the solution is to eliminate one of the 30 amp power supply connections and in the fuse panel bridge the 2 hot side supply rails, or better yet restore the power connection to the 50 amp service cable and purchase a 50 amp to 30 amp power adapter cable
Apr 05, 2012 | Cars & Trucks
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
After a storm, my TV will turn on and off, but it has lost its picture and it has lost all volume. I do not have it plugged into a surge protecter. Before I open the back and look for fuses, I thought...
post model number, take ac cord out of your tv & any cable or sat box you may have for 1 minute then replug tv & box to re-boot the micros, if still nothing set will need tv tech, gl, video-tek
Jun 10, 2009 | Hitachi Televison & Video
Over night the battery is dead
Put a 12v test light between the positive terminal and the battery cable.If the light is bright the draw is to much.A dim light is fine.if the light is bright,plug one fuse at a time until light dims.DO NOT cause a draw by leaving a door open etc while testing.DO NOT try and start the car or turn the key on during this test.Once you have found the fuse that causes the most draw,if you want to save $ you can just pull this fuse overnight or wire that circuit with a relay to unpower it when the vehicle is switched off.
Apr 28, 2017 | 2004 Dodge Neon
Power wire keep blowing fuses
you need to go tho a block fuse which will be able to handle more load but will still give way before the amp its self would get fried i recommend a 75 fuse or higher
Feb 21, 2009 | Orion HCCA 275G4 Car Audio Amplifier
Many channels do not come in. I feel it needs reprograming. I have cable .
Make sure that the set is in the correct mode. It sounds like the set is expecting TV signals from an antenna rather than cable. The cable channel assignments are different. Place the set into CABLE mode and autoprogram the set. That should resolve the problem.
Dan
Jul 07, 2008 | Orion1934 19" TV
Color on the screen
Try moving the speakers away from set.
May 11, 2008 | Orion1934 19" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Televison & Video Logo
194 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
