Question about GE JKP85 Electric Double Oven
No heat or rotate
Control panel operates normally. Timer counts down, fan turns on, oven light on. The turntable doesn't rotate and the microwave doesn't heat. Symptoms came on simultaneously. Perhaps not a coincidence, it occurred after popping two bags of microwave popcorn (possible low load problem?). I've already opened it up (yes, I read and adhered to all microwave maintenance safety guidelines). I checked all the connections and the only fuse I could see (20 amp, checked good). Put it back together and still no workee.
  • 1 more comment
  • NoWorkee Sep 03, 2007
    I guess door switches are the most common cause of microwave trouble. It works fine now after swapping out the door sensor switch. Cost less than $30. Thanks Bigg T.
  • Anonymous Nov 18, 2007
    Same problem for me....no rotation or heat. I looked at the door switchesand can only sat they seem o be clean and making good contact...how can i be sure its the switch?
    Kevin
  • Chriswin May 25, 2008
    I got the same problem, no rotate, no heat, others seems normal. My model is FEB1999.
    Chris
Hi, I have the same problem, no heat and no rotate.
How can I check the door switches, how can I determine it is good or bad.
Do I need to open that front panel on the right hand side to check the in side.
Thanks a lot.
Wendy
Posted on Mar 28, 2008
  • 640 Answers
Did you check the door switches?
Posted on Aug 19, 2007
Error E7 : F1 GMC275PDs07. Microwave works normally but will not heat. Magnetron changed out and still will not heat.
If your microwave is a 220 then reset the breaker by turning it off for 10 seconds and then back on. Then check it. Since you replaced the magnetron, the signal to the mag is interrupted. Did you replace the control panel? If so, then look to see if it is wired back in order. Does the fan operate when you open and close door? If not, then check door switch.
Feb 24, 2013 | Whirlpool GMC275PD Electric Double Oven
Magnetron fan runs all the time
The timer that runs the mag is stuck. Unplug fan for 30 seconds and check it out. If not fixed, then look at replacing if microwave is older 7-8 years old.
Feb 24, 2013 | GE JKP90SPSS 27" Microwave Combination...
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
My microwave 290HS was performing perfectly until one day when it stopped heating. I followed the steps given in the manual. The tray is rotating, the light inside goes off when the door is closed, the...
May be one of the components in the High Voltage circuit has failed...Usually there is a relay or semiconductor switching device that turns on a tube called a magnetron..this magnetron is what heats the food...any one of the components in these circuits could have failed...I would have a repairman look at it to see if would even be worth it to get it fixed.
Dec 20, 2010 | Ovens
There is no heat coming from the microwave part of the oven, although the grill, convection oven, motor, light and fan all work. The 8 amp fuse on the board where the mains cable enters the oven has blown....
Hello, If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.the magnetron i guess is kind of faulty and this is the most expensive part in a microwave oven.
If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system.
wish yo good luck,
take care.
Jul 19, 2010 | Ovens
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Cook timer keeps chiming
it starts chiming every min AFTER the timer counts down the allotted time?? thats normal operation its remonding you that the timer has completed cookin and to remove food from oven.. it will continue cooking with residual heat if not removed
Nov 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
Wont' heat in broil or bake
check incoming electric first, pull it out and gain access to main wire terminal, With multimeter set to at least 250v AC , check your power across the wiring as such. black to white (110v), red to white(110v) and then black to red 230v. if that ok ok turn, then start ckin elements for continuty also there might be a thermostat( usually an 1 in. round component with 2 wires located right inbetween the elements that has gone bad, will show no continuity. ck that before electronic control the fact that its clickin sounds like the relays are workin properly
Feb 23, 2008 | Ovens
GE JKP85 Electric Double Oven Logo
366 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
