Question about HP PL4245N 42 in. HD-Ready Plasma Television
Screen flashing This tv recently started this problem after about 5 months. After it is on for about an hour on bright images like sky there is intermitent pinkish shimmering on the screen. These flashes continue then until the set is shut down. Thanks
  • 1 more comment
  • Anonymous Nov 21, 2007
    tv screen looks like a strobe lite
  • meandsnook Mar 23, 2008
    Exact same problem. The picture is perfect for the first 10-15 minutes after being off for 12 or more hours. Once the flashing starts, it won't stop until the tv is off for another 10-12 hours. So, I get 10-15 minutes of quality viewing a day. GREAT BUY!
  • Anonymous Apr 12, 2008
    I have the same probelm. I guess I didn't get a good deal.
  • 3 Answers
You need the voltage on the ps board and the ysustain board adjusted. Possibly the z sustain board needs replaced if this doesn't fix.
Posted on Jan 14, 2008
SOURCE:
Problems with sky tv
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 12, 2017 | Televison & Video
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
Flashing screen on Toshiba 42HP66
Plasma sets use high voltage to produce their displays and it sounds very much like the HV supply is losing (or has lost) regulation likely due to the impending failure of a semiconductor.Check to see if Toshiba has any extended warranty on this since it could be a series problem.If there is none, ask for a price on a new or repaired supply on an exchange basis.
Dec 30, 2011 | Televison & Video
900 hours and I am seeing some image retention. How to remove them?
In a few words, you can't.
Panasonic Plasma Screens have a movement option that slowly moves the screen around a few milimetres
I the burning is bad and all you can see is Sky TV's frames or Sport frames, the way to reduce the effect, and this is official, is to turn up the screen brightness on a white background. This will burn the rest of the screen to a similar level!
Unbelievable but having done that for a number of hours, when one increases the brightness to compensate for a burnt screen, it is slightly better.
(I do not advocate that, I would not let it burn in the first place.)
Good luck
Hope that helps.
Dec 23, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Sep 30, 2008 | Toshiba 62HM15 62" Television
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
HP PL4245N 42 in. HD-Ready Plasma Television Logo
121 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
