Question about Samsung SP-R4232 42 in. Plasma HDTV
Electricity went out in town, tv won't turn back on.
Power in town went out. Now my 42" plasma does not turn on. No blue light. Where do I find trouble shooting information for my model TV?. product number not shown on samsung site: sp-r4232
  • nycam Aug 19, 2007
    I see a T8.0AH250Vac fuse which is opaque qhite- is this the possible culprit?
    Novelist:
  • 192 Answers
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Posted on Aug 19, 2007
  • Anonymous Aug 19, 2007
    I'm not at my shop, but, the fuse is white and it is a slow blow. What you described sounds like it.
    Either way check it and if it is open, then, that is probably the culprit.
    I think the reference number is F801.
  • jackie evans
    jackie evans Jan 28, 2014
    what do i do if this is the cause
SOURCE:
Why won't my Panasonic 42 TCP42S30 42 Plasma TV turn on.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service
technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Panasonic 42 TCP42S30 42 Plasma TV
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
Aug 19, 2011 | Samsung PN42A400 42 in. Plasma TV
LG 42" Plasma - remote wouldn't turn off TV, nor
unplug for a couple of hours. the tv holds charge and bleeds off electricity very slowly.
Mar 22, 2011 | LG 42PG20 42 in. Plasma HDTV
Will not power on
This will bge faulty capacitors in the power supply, Take the back of the TV and check the power board for capacitors that are bulged /swollon on top, they may also leak a brown like substance, usually they are around 1000uf / 10v
Change any that look suspect and if capacitor related this will resolve your issue.
Hope this helps
Apr 05, 2010 | Philips 42PF7220A 42 in. Plasma Television
Plasma lg 42'' not powering on after electricity went and came back , when tv was on(electricity blackout)
NO LIGHTS ATALL ON TV/ SURGE OF ELECTRICITY CAN BLOW INTERNAL FUSE/OPEN IT UP WERE THE MAINS LEAD GOES TO BOARD CHECK GLASS FUSE/SILLY I NO BUT CHECK PLUG/IF NOT DAMAGED POWER SUPPLY
IF SO OHM SUPPLIES FOR REPAIRS OR PARTS UK ONLY
Dec 04, 2009 | Televison & Video
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Samsung SP-R4232 42 in. Plasma HDTV Logo
371 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
