Samsung (SW-208) CD-RW Burner Logo
A
Anonymous Posted on Jun 04, 2013
Samsung dvd writer SE-208 nero software free download
5 Related Answers
A
Anonymous
  • Posted on Dec 10, 2007
SOURCE: Samsung DVD writer SH-S182 problem
try a different power connector from psu,do not share same as HD!!should work!!
Anonymous
  • 258 Answers
  • Posted on Apr 10, 2010
SOURCE: i m using samsung octo edge dvd writer
To use "Burn DVD video files" in Nero, you have to switch on Advanced mode instead of standard.
In my version, this is what the bottom right corner of Nero StartSmart Essentials looks like in the two modes.
Testimonial: "Thanks for the help"
Anonymous
  • 109 Answers
  • Posted on Jun 03, 2010
SOURCE: i have the samsung se-s084 dvd writer
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Please let me know if it works...
Testimonial: "in my comments before i was looking in the wrong area i found the filters and deleted them as you said.You sir are a genious and my external drive showed up thanks very much really means a lot to me"
Saigua
Steve Nordquist
  • 982 Answers
  • Posted on Feb 28, 2011
SOURCE: hey...i have an external dvd writer of samsung
If you format a machine's drive, nothing should work at all, though some will be able to boot an OS from the DVD-R depending on the laptop model and BIOS settings available.
If you installed an OS, just install some ISO-9660 drivers for removable media for (I assume) WinXP and it's usable. Any other OS should be fine as it came. Mind, both plugs have to be in a powered USB hub, but there is no driver per se except the one from the OS (or preferably, Nero Suite (from Ahead Software, Ahead.de .)) You may also want a forensic DVD tool for the inevitable bit rot over the years since DVD came out so you can still read most data and not have the OS tell you the drive just isn't up to it; though it's possible it accumulated dust if you have used it enough and needs a cleaning disc from time to time.
Anonymous
  • 141 Answers
  • Posted on May 07, 2011
SOURCE: can i download user manual for "Samsung super
http://www.manualsmania.com/model.php?model=8fbe474996731fc2f63e0b9978d4c0634ed3ae
1helpful
Samsung Portable DVD Writer SE-208,how to install software to read disc, no manual supplied with product.
Rivka jacker.
no OS stated no PC stated.
plug it in,
if the OS is not old , it PnP (web connected PC only)
and it works.
I have the $12 clone of this ext dvd drive and works on all machine in my house and lab. easy as pie, plug and play.
tip
Nero Serial code key for registration
You can obtain a free nero burning rom 9 download and a serial key emailed to your email from ahead software / nero by signing up to the free trial - this will let you use the software legally as a trial for around 15 days, during this time you can burn dvd, cd and other media for free.
http://www.nero.com/eng/downloads-nero9-trial.php
After the trial is over, you must purchase the program, if you can't afford the program and if you want to get it cheaper than what they are asking for it, buy a new CD/DVD burner that has nero software included those generally cost around 20 to 30 $ from www.newegg.com
if you can't afford that either, then there are free alternatives to nero. For example cdburnerxp is a great program that will get the job done, it will burn your cd and dvds for free. Download -http://cdburnerxp.se/
Thank you for reading
Ekse
Please write feedback, comments, suggestions etc below.
dvd burning software review dvd burning software free download free dvd burning free dvd burn how to burn a dvd dvd burning programs how to burn dvd software to burn dvd burner software burn to dvd free dvd burning software burning download cd burning software burn cd dvd burn cd incd software cd dvd burning software dvd burn software dvd burning software reviews cd burn software best dvd burning software free burning software burning cd dvd free cd dvd burning software burn dvd dvd burning software burning software burning dvds cd burning dvd burning
How can I use my external dvd writer of dell vostro 1014 for boot?
You can ONLY boot up from the USB DVD drive if the BIOS has the option in the boot order that allows the USB to be the first boot device.
How download this software i want iomega DVD/CD writer plz help
There really isn't software that you need to burn DVDs or CDs with Windows. Use Windows Media Center to burn your CDs or DVDs.
Here are some burning software links below or you can google search for some.
Mac http://www.techmixer.com/best-free-mac-burning-software-for-mac-osx/ http://www.burnworld.com/software/cdrburning/mac-burning-software.htm
Windows http://cdburnerxp.se/en/home http://www.nero.com/enu/
I have just bought a sumsung external dvd writer se-so84c. Not only can I get any sound on playback dvd's although cd's seem ok, but also I am unable to record dvd's onto my sony vpcm12m1e which uses...
maybe your sound problem you can fixit with k-lite codec pack, download and install , you can use xp, vista . 7 etc, if cant burn use the last version of nero abalable
2helpful
SAMSUNG DVD Writer . Have lost Key Number What to do
You may ask your retailer. If there is nothing specific in NERO then you can use any free tool.There are many free CD/DVD writing softwares on the net.Search in downloads.com and google.
Don't loose heart this is not a big problem.Register your DVD writer on SAMSUNG website and then drop a mail to support on the same website for the key, they may respond.
2helpful
5answers
To get nero burner
You get all legal downloads for nero clicking here: Download Nero.
Illegal and pirate software is not allowed on Fixya.
Lost mydvd writer software disc
hi sandy.....
first open dis site....
http://www.brothersoft.com/downloads/nero-7.html
n download nero 6.6.1.4
n its seriall no. is:-
1A23-0009-6030-2391-0264-0105
ask me if u r havin more problems....
thanks....
2answers
Lost installation CDrom for Samsung DVD Writer SE-S204N
you may not need that install discs, maybe just the burning software that came with your writer, most probably from nero or roxio.you can visit their [articular websites where you can download a free standard versions of the program.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
