Question about Apple iPod nano
Frozen iPod nano
IPod not recognised by PC iPod screen alternates blank, light gray apple icon then bright white apple icon. continues this until battery runs out. does not respond to reset.
  • Anonymous Nov 03, 2007
    shows apple logo when restarted then plays music with a bright white screen
  • 31 Answers
Try to put the ipod into disk mode, while connected to PC, perform first hard reset by holding select and menu buttons until it restarts, when quickly change to pressing select and play buttons, then it must go into disk mode, will sync with PC and must show in iTunes, perform restore function to reformat the memory
Posted on Aug 20, 2007
This totally works - thanks so much. I thought my Ipod was toast. :)
Posted on Oct 29, 2007
SOURCE:
How do i fix my ipod
Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. b> Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. b> iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact.
iPod into Diagnostic Mode
http://www.methodshop.com/gadgets/ipodsupport/diagnosticmode/index.shtml
Apr 18, 2013 | Apple Audio Players & Recorders
IPod Nano screen on and blank
This is all I could locate: Reflash it using the updater program or call apple. Also see: http://www.gadgetizer.com/2005/09/12/ipod-nano-updates/
Nov 13, 2007 | Apple iPod nano
My ipod screen has gone blank
Hold the home button and the power button at the same time and wait until the device shows the Apple logo on your screen (should take around 30 seconds).
Dec 11, 2017 | Apple iPod nano 3rd Generation
My ipod is frozen
I have provided a link related to your problem, use that link to help solve the problem.
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm
Good Luck
Jul 03, 2009 | Apple iPod nano MP3 Player
My 16gb ipod has a blank white screen. how do i fix it ?
hold the center button and the menu button until you see a black screen with the apple logo then wait and see what happens
Jun 11, 2009 | Apple iPod nano
Ipod nano frozen
there are 2 basic ways the harder one is:
leave it on all night until it runs out of power then charge it and it should work
The easy way:
hold the menu and select button down for a while until the apple logo apears, if it dosnt work follow the harder way
Nov 28, 2008 | Apple iPod nano 3rd Generation
IPOD NANO 1st Gen. 2GB HANGED
THIS WILL SOLVE YOUR PROBLEM!
1.Turn on HOLD then switch it off
2. Press and hold the "Play/Pause" Button and the Center button at the same time until it resets the iPod.
This should reset your iPod and fix your hung (frozen) iPod!!!
Jun 27, 2008 | Apple iPod nano
IPOD NANO - Starts With White Screen, Stays With White Screen. Can't see Anything.
1 Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
2 Press and hold the Center and Menu buttons for at least 6 seconds, until the
Apple logo appears. this resets the ipod
Mar 16, 2008 | Apple iPod nano
Frozen Ipod Nano
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  3. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  4. Connect it to your computer.
  5. In iTunes, select Restore to Restore the iPod firmware. This erase everything on the iPod.
Dec 04, 2007 | Apple iPod nano
Apple iPod nano Logo
238 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Parshiv Luthra
Marvin
Marvin
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
