Question about Sony Cyber-shot DSC-W50 Digital Camera
Same problem: "TUrn your camera off and then on"
This is the same problem that it seems others have had where I can't turn my camera on. The zoom opens and shuts a few times, and then it just closes and says "Turn your camera off and then on." I literally just got this camera last week :(
    Problem Solver:
  • 5 Answers
Well this might seem too simple. But I would take it back, get a new one that works perfectly out of the box.
Posted on Aug 23, 2007
SOURCE:
My camera is zooming in and one edge of the lenses is higher than the other one
Due to regular dropping it internal parts seem to have become loose and thus are not in control. Try getting it checked it at the service center to change the loose parts
May 16, 2017 | Fuji Cameras
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
My Canon S3IS shuts down during zooming. What's the solution ?
It could be the batteries running low. The mechanical zoom consumes battery power and at a certain point the camera will turn itself off. If you wait a minute and turn it back on it seems OK, until you try the zoom again. If you are using non-Canon batteries the camera doesn't always detect the battery level accurately and may flash "low battery" when there is still power remaining, or just turn itself off without warning. So I suggest changing the batteries and check that the battery terminals are not dirty or loose.
Mar 25, 2010 | Canon Cameras
Batteries die within 1/2 hour & zoom does not work
Are your batteries good? There are special Lithium batteries that are designed for cameras.
Aug 14, 2009 | Canon PowerShot A590 IS Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Zoom error
I had the same problem with my 6-month old Olympus SP-560UZ  and was quite upset until I thought of a way around this. The error seems to be due to the lens becoming off axis and not extending. I was able to turn on the camera by lying it down flat on its back so the lens will extend straight up when the camera is powered up. Once it is turned on, it seems ok to move it back in its normal position.
So far so good - and it is free…
Sep 19, 2008 | Cameras
Flashing Red Light
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
Sep 24, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
My camera wont turn off
I've purchased several of these cameras used as we liked our first on and it eventually failed with this same problem. I have had four of these now and they all end up with this same problem. Take the battery out then turn the selector to any new position and then off, put the battery back it and the lens should recline and camera turn off. One of the cameras would then work for a while after doing this but then hang up again. I think this is a very common problem based on my experience but no other confirmation than yours.
Jun 09, 2007 | Canon Sure Shot 105 Zoom Date 35mm Point...
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
