Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
"Door Locked" Indicator Switch Faulty
LG WM2075CW (TROMM Ultra Capacity)Front Loading Washer When the front door of the washer is fully, properly and securely closed - and the start button is depressed - an alarm sounds, the "Door Locked" indicator flashes and the washer won't start. The door has to be opened and closed several times - at just the right angle and with just the right amount of pressure (by pressing hard against it) - to get the indicator to recognize that the front door is closed and the washer to start. This problem is intermittent and no one ?technique? works every time.
  • Natalie Housh May 11, 2010
    Is there a way to fix this same problem? The "PF" keep flashing on my LG wm2075cw front loader. I do not know what it means. The buttons are now also not working properly. What can I do about that?
  • Anonymous Mar 12, 2014
    I have a Ge profile washer, over the last few years it has gotten harder to close the door, replaced door lock switch, now it will not close and lock unless I hold alot of pressure to the door, it has always had a problem closing, just has gotten a lot worse. Any ideas, could the rubber seal need replacing.
  • 641 Answers
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Posted on Aug 21, 2007
SOURCE:
Front loading washer door should it be left open or closed when no use.
I recommend leaving the door slightly ajar when not in use. That way your rubber boot/door gasket doesn't get smelly or stinky.
-Colleen @ MendingShed
May 05, 2015 | LG Tromm Front Load Washer And Dryer Set
Washer won"t turn on outlet is working
If the washer won't start, the user control and display board or the main control board may be defective. The main control board failure is not common. Check other parts and causes first.
If there is power to the display and the machine wont start, check that the door is latching properly as there is a switch in the door latch that tells the control board when the door is properly closed. The switch might be faulty.
Feb 16, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer WM2075CW -The dispenser is stuck, only pulls out aprox 1/2
Yes you are correct, fabric softener dispenser is culprit. Search on this site for solutions. Issues and solutions have been posted often.
May 04, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
LG WASHER LEAKING WATER FROM THE DOOR
The manufacturer recommends using washers and shimming the door latch between frame and switch. This will make the door close tighter.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 29, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Front loader LG Washer
make sure your outlet hose is not constricted or blocked in any way.
May 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
558 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
