Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
How tounlock my iphone simlock
By coopers on Aug 18, 2007
hi there, how can i unlock my iphone sim lock?
Same Problem
May 05, 2009
-   How to unlock my iphone mini -   Guest
Mar 26, 2009
-   its wont restore it says sim locked
-   Guest
Nov 14, 2008
-   i updated the new software but itunes replied that my simcard not supported -   ronyring
Nov 14, 2008
-   i get a new iphone 3G 16GB, when i put my sim card into my iphone idont have any numbers , but i can call !i dont know what i have to do , can you help me?my phone book is empty when i add new entry , i cant see any numbers in my phone book -   pstefaniak
Nov 14, 2008
-   kfgf -   Guest
Best Solution
posted on Mar 17, 2008
Helpful)
crafties
Rank: Wiz
Rating: 81%, 62 votes
if your sim is locked you just ring your service provider and ask them for your puk code. the sim is locked...not the phone
Was this helpful?
Yes
No
Solution #2
posted on May 29, 2009
Very Helpful)
jocoolguy
Rank: Guru
Rating: 86%, 64 votes
IF IT IS MOBILE LOCKED EASY TO UNLOCK JUST VISITING THIS SITE http://www.unlock-zone.com/ THROUGH UNLOCK MOBILE CAN BE DONE, BUT HERE THE SITUATION IS LITTLE DIFFERENT SIM LOCK, THE ONLY WAY HAVE TO CONTACT SERVICE PROVIDER OR CUSTOMER CARE..
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Nov 17, 2008
Very Helpful)
micekozy
Rank: Apprentice
Rating: 100%, 2 votes
how do i unlock my simlock on my iphone
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Nov 16, 2008
Very Helpful)
hasanay83
Rank: Apprentice
Rating: 100%, 1 votes
hı dear ı download 2.1 versıon of ı phone and sımlock ıs blocked how can ı open
Was this helpful?
Yes
No
Solution #5
posted on Aug 07, 2009
Somewhat Helpful)
jemaal
Rank: Master
Rating: 77%, 47 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Thanks
Was this helpful?
Yes
No
Solution #6
Somewhat Helpful)
enopog
Rank: Master
Rating: 76%, 21 votes
Problem with AppleiPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock youriPhone now you mustClick Here.
If you have any other problem with your iPhone you can try the site byClick Here. May the site can help you.
Was this helpful?
Yes
No
Solution #7
posted on Jan 14, 2008
Not Rated)
adamqqq
Rank: Guide
Rating: 90%, 3 votes
Try www.hacktheiphone.com
That has EVERYTHING!!
Was this helpful?
Yes
No
Solution #8
posted on Dec 03, 2007
Not Rated)
nasuru
Rank: Guide
Rating: 79%, 132 votes
this can be do in total two methodes (os and windows)
with help of os method:it totally take 7steps (be careful to do this)
first step:Download the virginizer package here. the two downloads the iPhone Elite Dev Team hosts on their site, just to eliminate any possible mistakes in finding all the needed files, or in properly merging them
second step: so make sure you are following all of this.
You must have:
  • an iPhone with 1.0.2 firmware which is currently working.
  • a fully charged battery.
  • 03.x series modem firmware (mine is 03.14.08_G).
  • a patched lockdownd file already installed. If you don't and use a non-AT&T SIM your iPhone will leave you at the activate screen which you will need to bypass before continuing.
  • BSD SubSystem and OpenSSH installed.
  • Mobile Terminal or Term-vt100 installed (just in case you lose Wi-Fi).
  • the ability to use Fugu
step 3
Plug in your iPhone to your Mac. Quit/close iTunes. Don't just minimize it, shut it down. If you have the iTunes Helper open, you must quit that as well. To determine if they are running, open the Activity Monitor program found in the Utilities folder inside of the Applications folder. If it is running, highlight it in the list and click the "Quit Process" button.
step 4
If you are using any program (like Services) that gives you the ability to turn off your SSH server on your iPhone, then make sure your SSH server is turned on right now.
Also, make sure to press your Home button, then press "Settings", "General", "Auto-Lock" and "Never". It would be disastrous if the iPhone went into sleep mode during this process.
step 5
1)Launch Fugu. Copy the "virginizer_pack" folder (which you downloaded in Step 1), to the /usr/bin directory on the iPhone
2)Go into the virginzer_pack folder on the iPhone. Make sure the following files all have executable permissions (preferably 0755) set so they will run:
bbupdater, eliteloader.bin, iUnlock, norz, virginator.sh
If you don't know how to change the permissions, simply right click the file
3)Enter 0755 into the field next to "Octal Mode Representation:". Then click the "Apply" button. Do this for every file
4)Your folder should look like this when you are done.
5)Launch the Terminal. I did this on my Mac since I needed to take screen shots, but you could do this directly from your iPhone.
step 6
Type: ssh -l root (your iPhone's IP address) PRESS RETURN
Type: (your password at the prompt) PRESS RETURN
Type: cd /usr/bin/virginizer_pack PRESS RETURN
./virginator.sh PRESS RETURN
Now just follow the prompts. 1....2.........yes
****Note: at ths point a seczone.backup file has been created. If you click "Reload" in Fugu you can be extra paranoid if you want and back that file up right now. Close Fugu when you are done. *******
A lot of code will scroll by as the flashing process continues. Eventually it will end with a prompt symbol
If you haven't already quit Fugu, you should now. I noticed that even after closing it the following command didn't work for a couple minutes. So if it fails the first time, try it again later.
Type: ./bbupdater -v PRESS RETURN
You should have the same output I have here
You can close the Terminal and restart the iPhone.
Note: Your iPhone is now running 1.0.2 firmware with repaired 03.14.08_G modem firmware. Continue below to update your iPhone to 1.1.1 firmware and 04.01.13_G modem firmware. Your iPhone will be locked after continuing.
step 7
1)Launch iTunes and click "Install".
2) updated A LOT of iPhones in my time and this one took a very long time to update. So don't panic.
3)
When the iPhone starts it'll be at the activate screen. iTunes will display the Welcome to Your New iPhone screen
While I'm not going to go into depth on this, you could use the emergency keypad exploit (dial *#307# then 0 then make a contact with a home page URL of prefs://1F) to go into the settings screen to verify that you are on 1.1.1 with a modem version of 04.01.13_G. But you really don't need to.
I recommend now following my Step 1 tutorial to proceed with the jailbreaking and unlocking of the iPhone.
before u do this be carefull my friend..................
Was this helpful?
Yes
No
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
it's fully charged and had turned its self off, but wont turn it's self on again
Answer
i was texting like 2 minutes before then i looked at my iphone and it wasnt turning on
Answer
I cannot get my iphone to turn on at all. Not even by pushing "both" buttons at top and...
Answer
can i use noteworthy synch to sync iphone to outlook express 6 winxp
Answer
i was taking pic yesterday,, the next moment my i phone is zoomes..the font is to big and i cant... (More)
13 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 06, 2008
sim lock
Comment by Guest, posted on May 18, 2008
well i downloaded and update and now i tunes isnt recoginizing my sim card.
Comment by Guest, posted on Apr 24, 2008
I have my PUK but cannot find how to input it onto my iPhone
Comment by Guest, posted on Dec 25, 2007
how to unlock iphone simlock problem.
Comment by Guest, posted on Dec 13, 2007
cant move anything on the screen
Comment by Guest, posted on Dec 02, 2007
locked sim card and need default puk code
Comment by Guest, posted on Nov 16, 2007
sim lock
Comment by Guest, posted on Nov 06, 2007
how to unlock iphone with other sim
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDAs Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
