Question about IBM ThinkPad T20 2647 Notebook
My notebook wont start up
My notebook keeps on saying press F1 for Ibm Bios setup utility and under that it says press F12 for to choose temporary boot device and when i dont click anything it goes to this black screen and words apear like oak technolgy and mscdex.exe and stuff like that so can anyone help me get to the main screen that would be helpfull
  • acorn123 Aug 18, 2007
    please i need help with this problem guys
  • rfreeman07 Nov 11, 2008
    Yes I have the same problem. I just get an IBM logo w/the same choices for f1 and f12. It just hangs if I select one. I thought maybe cmos battery was dead but it looks like it might be rechargable. Is that right? So anyway it won't boot from disk, it wont let me in the bios at all. I'm stuck please help.
    Scholar:
  • 181 Answers
Have you ever been able toboot this machine? Sounds like you have a corporate machine which is configured to boot with several options. If that's the case, you should re-load windows. Get back to me if that's the case. Thanks, harvester3
Posted on Aug 18, 2007
SOURCE:
My pc can't start just IBM logo and Press F1 for IBM BIOS setup utility Press F12 to choose temporary boot device
Go to bios setup and see if the unit is detecting the hard disc drive...it should be on the first page of bios...if it does "see" the hard disc, then get out of setup and go to F12. (you will need your operating system disc for this next step). Choose to boot from the cd. It may ask you if you are sure you want to do this. The operating system will ask you what you want to do. Select the option from the list. It may ask you if you want to repair the installation...select this option if avail....if not, depending on which O/S you have , you may be able to reload the system without losing what you have stored on the computer. If at anytime it asks you to reformat the hard disk..you don't want to do this as this will erase everything on the hard disk drive. Now, if the computer does not "see" the hard disk in the BIOS menu, then your hard drive may have failed and you will need to obtain a new one and reload it with the O/S and all software you want...unfortunately...if the hard disc is bad then you will have lost all info on it...there are some data recovery services out there...but they can be expensive(depending on how important your data is).
Jan 03, 2011 | Computers & Internet
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
I have an old IBM THINKPAD R31 every time i turn it on it says to press F1 for ibm bios setup utility and F12 for ibm boot devices list so i pres one of the 2 and it does nothing it just stays the same...
This is caused by the small battery inside that keeps the time and date for the computer. If it is dead, you get the message you refer to. Sometimes they are easy to change, sometimes it is quite a hassle. If you go to setup, you can change the time and date for that session, but the next time it will be off again.
Aug 09, 2010 | IBM ThinkPad R31 2656 Notebook
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
Ibm t21 turn on to start up page with diaganol ibm logo and press f1 for bios f12 for temporary boot device,but it just hangs there the f1 & f12 buttons dont do anything any help much appreciated
The cpu looking for a file or driver so go to F1 and click on F10 and exit and see what will happen? If that did not work restart the computer and keep clicking on F8 tell you get a new menu asking you to select one of the followings, one of them safe mode, or last know good configurations, etc. Select last know good startup.
If you need help with anyone then please let me know and I will help with it. Please do not forget to rate my service so we can improve on it with your help. God bless
Sep 30, 2009 | IBM ThinkPad T21 Notebook
Startup problem
check the device like ram,or hdd. or change the battery cmos.. then try again
Jun 14, 2009 | IBM (33P0825) Motherboard
Unable to Acces BIOS on IBM Netvista 607931u w/ Phoenix ROM BIOS
When the IBM Setup Utility program prompt is displayed, quickly press F1.
The prompt is displayed for only a short time.
if you dont see the prompt, tap F1 repeatedly as the computer starts. If it says "starting windows" you've let it go too far and will have to restart again and repeat the process to get into the bios
REGARDS..
Apr 09, 2009 | IBM NetVista PC Desktop
Lap to stops on Bios screen
Reseat your RAM modules, remove and insert them a few times so they make proper electrical contact in the slots.
Jan 15, 2009 | IBM ThinkPad T21 Notebook
IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Dec 13, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad T20 2647 Notebook Logo
162 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
