Anonymous Posted on Jun 05, 2013
Multi-usage Can I install this scanner on all 3 ( laptop,desktop and blackberry playbook?
ONE-Touch-Solution
Level 3:
  • Master 1,679 Answers
  • Posted on Jun 05, 2013
ONE-Touch-Solution
Master
Level 3:
Answers
1679
Questions
Helped
404827
Points
5442
Hi Anthony,
Scanner can be installed on network ( if it is network compatible ) and can be used from Laptop and Desktop. Blackberry is not possible as it will fail.
Regards,
Sean
I have one more attempt at my password and it will wipe out my memory. How do I recover or set a new password?
  1. Use a browser in the BlackBerry PlayBook or a personal or laptop computer and go to the BlackBerry ID Password Reset page.
  2. Enter your username (your BlackBerry ID) in the first box.
  3. Enter the slightly scrambled verification code in the second box. The CAPTCHA system helps prevent computerized attempts at cracking password codes; presumably humans are better at reading those oddly shaped characters. If you have trouble with one set, tap Refresh the Image to get a new group.
  4. Click Submit.
    If you've done it correctly, a confirmation message tells you that reset instructions have been sent to the BlackBerry ID e-mail address. For security reasons, the reset instructions don't go to your BlackBerry smartphone or to your BlackBerry PlayBook. The idea is to prevent an unauthorized user from picking up either device and gaining control of it.
  5. On a personal or laptop computer, log in to the e-mail account you specified and find the message.
    You can log in also on any other e-mail-capable device other than your BlackBerry PlayBook or BlackBerry smartphone. The message comes from [email protected]. If you can't find it, check the spam folder.
  6. Click the link in the message.
    A web browser should load on the device; if it doesn't, tap the link and copy; then open a browser and paste it there.
  7. When the password reset page loads, enter a new password for your BlackBerry ID.
  8. Now confirm.
How to Reset BlackBerry ID Password for Your PlayBook
Hi, i have a black berry notebook that not charged! I thought it was the charged but i order one and still not working!
Connect it to a PC that has the latest Blackberry desktop software installed and update the OS on the Playbook. If the computer will not detect that Playbook might be toast. I just tossed one that would recognize but the power button was bad and the batteries were oozing fluid.
How to connect blackberry playbook to desktop running on windows
Hi,Friends...
You can connect blackberry to desktop. no any issue flow instruction.>
Note: Make sure you have the BlackBerry Desktop Software/ Device Manager installed first. Before you continue. Well, it didn't take me long to figure out the issue. All you have to do is unplug the Playbook, go to your Settings > Storage & Sharing (Make sure "File Sharing" is switched to "ON) > Switch "Wi-Fi Sharing to "OFF" > Select "Connect to Windows" under "USB Connections" drop menu. Go back to your BB Desktop Software. Go to, Tools > Refresh iTunes Album Art. (Note: It can take a few minutes depending iTunes Library size) Plug your BlackBerry Playbook back to your PC through the USB connection, wait for it to load and you should be able to Sync your Files. Thanks
Blackberry playbook hanging
Apparently it needs to be reformatted. Connect it to your computer and use the blackberry software on it to RESTORE OR UPGRADE the OS on the device.
I want to sinc my Blackberry Playbook to my Windows 7
You need the Blackberry Desktop software installed on the computer to synch your data, music, and video on the Playbook to that on the PC. This software is available here: https://swdownloads.blackberry.com/Downloads/browseSoftware.do;jsessionid=F3B0494BF2ABF9E47D9531B30BD6E7BF.node1 . The direct link to the multi-language version of the software is: https://swdownloads.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=A2C0D61EB187AB3AFD247A852FAD3647 .
If the above links do not work, start here: http://us.blackberry.com/support/apps-and-software/desktop-pc.html and click on the Downloads for Blackberry Desktop Software. Then use the drop-down menu to select Blackberry Desktop Software Windows OS. Then download the .exe. Below you will find individual language versions. Install the software (in Win7 you need to be the Administrator).
Enable Bluetooth on the computer and pair the computer to the Blackberry.
See http://docs.blackberry.com/en/smartphone_users/deliverables/43033/1196187.jsp for more information.
Next click on Device -> Device Options and go to the General tab. Then set the "When I connect my device" items for those you want to have synchronized.
I hope this helps.
2answers
When setting up blackberry playbook for first time. it wont let me select a country on the agreement page
The Playbook attempts to download the license agreement from http://csbeta.websl.eval.blackberry.com/
and it seems this URL is no longer valid, as it returns
"Sorry! Nothing could be found here."
i figured the OS on my playbook is an early release so i'll be forcing an update.
to force an update, i fired up the latest desktop manager, completely turned off the playbook by pressing/holding the power button then clicking turn off, then i plugged it in..
desktop manager then shows an error message and gives you the option to update.. click that and leave it alone for an hour++ (depending on your internet connection)
i started the updated playbook, went through the setup wizard and this time when i selected the country, i got the license agreement and was able to continue.
option 2:
k24674
ADMIN Andrew
ADMIN Andrew
