Copy following link:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Otherwise there are 100s of atwood water heater resources on internet covering the different models old and newer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Atwood water heater - pilot light and flame malfunction
Michael,
The thermocouple sensor may not be in the best position to sense that the pilot is lit.
Adjust the thermocouple mount or simply bend the thermocouple "wire" so that the pilot flame is touching the tip.
SOURCE: Have an G6A-8E Atwood water heater. It Starts fine...
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
SOURCE: Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
SOURCE: atwood water heater lights and goes off. i can hit
Remove the wires at both ends of the thermal cut-off that is located in the little plastic sleeve below the pressure relief valve area and it's connected to spade connector on thermostat disc. Once removed, connect the female spade from wire to male spade on thermostat disc, and try to light now. If all's o.k. replace thermal cut-off as it is a safety feature to protect in case of flame up.
If not, get back to me.
