Question about JVC KT-PK2000 SIRIUS Radio Receiver with Car Kit
Backlight Can the display screen backlight be replaced or is the unit a throwaway? My unit is about 2 years old and the screen backlight burned out, only the screen the button lights are fine.
  • 1 more comment
  • deebowlby Nov 18, 2007
    I'm having the same problem. The audio is fine, and all the buttons are fine and working. I can change the channels just fine but just can't see what's playing because the display light is out. Makes it a bit difficult to find the channel you need to switch to. My unit is exactly 2 years old and I'm not ready to spend more money on a new one just yet.
    [email protected]
  • Anonymous Jan 09, 2008
    Just last week my backlight flickered on and off a few times and now it is lights out. The buttons light up but it takes holding it at an angle in a bright light to read the display. This is my second one I have owned as the first unit stopped broadcasting in stereo. I am finished with JVC products! JVC = Just Very Crappy!
  • JoeyTwoPutts May 24, 2008
    I have the same backlight problem. Does anyone know if it can be fixed?
My JVC does the same thing. i called sirius to cancel my subscription because of this reason and they are sending me a free cheap InV as a replacement.
Posted on Feb 21, 2008
SOURCE:
Upper sise of screen flickering problem
Technology b> A laptop's display assembly consists of an LCD panel, an inverter board and a backlight lamp. The inverter board supplies power to the lamp which lights up the LCD screen as it generates images. Light from the lamp is then uniformly distributed over the panel to create images. b> Cause b> Flickering is commonly caused by a damaged or malfunctioning inverter. Because a faulty inverter is not able to supply adequate power to the backlight lamp, the screen goes dim each time the backlight loses power. In some cases, flickering may also be caused by a faulty connection between the inverter and backlight lamp. Diagnosis b> Resolving a laptop screen's flickering problem entails correctly diagnosing the problem and replacing the faulty component. You may diagnose the problem by hooking up the laptop to an external display unit, such as a projector. If the external display has the same display problem as the laptop's LCD screen, it is indicative of a motherboard or video card problem. If the external unit displays bright, crisp images, the problem is probably caused by the backlight or inverter. b> Solution b> You may repair a laptop screen's flickering problem by replacing the inverter board or backlight. Order parts from a trusted supplier and replace the component by referring to your product documentation.
http://www.tech-faq.com/how-to-repair-a-laptop-screen.html http://www.laptop-repair.info/laptop_screen_repair.html b> Hope this helps.
Jan 21, 2013 | Lenovo IdeaPad S300 59359327 Silver Gray...
No backlight
A) Replacement LCD screen backlight could be bad.
Happens. Sometimes you get a bad part. (Bad LCD screen assembly, in this case)
LCD screen may not be the correct one.
http://support.gateway.com/s/Mobile/2008/GodzillaFX/2528410R/2528410Rsp2.shtml
http://support.gateway.com/s/Mobile/2008/Godzilla/2528407R/2528407Rmv.shtml
A screen Inverter, and an LCD screen; are a MATCHED unit.
B) Screen Inverter:
May be bad, or the Wrong one
C) You may not have the screen Inverter, connected correctly to the Backlight.
Connections aren't tight.
D) The Display Cable TO LCD screen connection may not be tight, or correctly connected.
I know the display shows graphics, but a poor connection of Display Cable to LCD screen, can make the Backlight dim out.
I'm betting it is a poor connection, or the wrong screen Inverter, or wrong LCD screen.
Regards,
joecoolvette
(Be shame to kick that laptop to the curb. Nice laptop)
Jan 07, 2013 | Gateway P-6860FX Notebook
Mc3090 CONTRAST ADJUSTMENT
Brightness can be adjusted by the hotkeys or within windows (system settings - backlight).
contrast can be adjusted with a potentiometer at the mainboard.
normally contrast does not change over the lifetime (my oldest 3090 is used 8h/day for 7 years)
some of the old 3090 have a CCFL backlight which dramatically losing brightness when getting old. you have to replace the tube or display unit.
Jul 09, 2012 | Symbol Motorola MC3090 Handheld Computer
Acer Aspire 5610 LCD backlight problem
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
Nov 05, 2009 | Acer Aspire 3680 Laptop
Backlight flickers 2 years old to the date do you
Furuno has similar displays. I don't know if Eagle provides the same support but you may be able to find an actual schematic diagram technical manual from them if you ask nicely i don't know if Eagle has any government contracts but you can try and tell them you are with some government agency like DOD navy or coast guard or homeland security ;) and see if they will send you a PDF of the manual also try Retrevo.com they may have the techmanual on file. It sounds most likely like a connector problem between the LCD and the power supply. Does it only happen out on the water (vibration or shaking)?
Aug 19, 2009 | Eagle SeaCharter 642C DF iGPS
W810i display backlight problem
You will have to replace this off eBay Im afraid, I have one in the shop but I would'nt be selling it on here or private. It would be listed on eBay or for my customers.
Feb 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My 3 year old Dell Inspiron 710m screen won't light up
to see if its your backlight, shine a torch onto the screen and if all is visible then, your backlight is out.
they are not expensive but getting someone to replace it may be.
Dec 20, 2008 | Dell Inspiron 710m Notebook
Backlight issue with the Vista HCx
I called Garmin. This is "As Designed", so we are stuck with this. Annoying, but all you have to do after turning the unit on is:
1) Press Lower Right button twice
2) Press Upper Right button once
Unit will now behave as you directed until you turn it off
Dec 14, 2008 | Garmin eTrex Vista HCx Handheld GPS...
I have a gateway monitor it shuts off a few minutes after I turn it and during use.I get a black screen?? it is only 2 years old. [email protected]
If it is a flat screen LCD monitor, the flourescent backlight is burned out.
Not too hard to replace.
Check eBay.
Oct 10, 2008 | Office Equipment & Supplies
Display lost brightness
forthe cost of the unit vs. the cost of having it serviced , ive decided to work on it myself. I have it narrowed down to the flourescent backlight or the backlight power curcuit.
Sep 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
JVC KT-PK2000 SIRIUS Radio Receiver with Car Kit Logo
355 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
