Question about kawasaki PVS1965 Portable DVD Player
Extra screens Does anyone know if you can purchase a splitter and add additional screens?
Target sells an item which should work. It's the Kawasai AVM678 or the Audiovox AVM6781 (http://www.target.com/gp/detail.html/sr=1-1/qid=1187573577/ref=sr_1_1/602-4888693-8663026?ie=UTF8&asin=B000I5IYAA). It's a universal extra screen. Otherwise, visit the official customer service website for this product at http://www.1800customersupport.com/kawasaki or or call them at 1-877-252-6873. They can probably sell you a splitter or additional screens.
Posted on Aug 20, 2007
SOURCE:
I want to add extra headset to at&t digital answering system Dect 6.0
go to ebay or radioshack and get a 3mm headphone splitter will allow you to plug in 2 sets
Dec 04, 2011 | Radio Communications
Hi , is it possible to add an extra 2 speakers to my hifi even though there are only enough terminals to hold the 2 that was with it ???? also the run of cable nedded for the added 2 speakers will be...
Yes you can add two additional speakers, by adding a splitter off each terminal, which will take each terminal hole to two. However there is a couple problems you might discover. Power output will weaken because each channel is designed for so much amp output. So, by adding two additional speakers off those channels demands more power. Now, if your not going to crank them high and have a block party you will be ok. You can get the splitter that goes in to each port and splits and places like Guitar center, maybe radio shack, best buy, and even check walmart.They make also little devices that are a little unit that actually is separate, that hook up like this. Two small coax lines about 6 inches long come out your receiver and plug into this little splitter that has four ports, then you can run all four of your lines to the four speakers, and this device has panning and some other little features to make one speaker louder than the other like a fader. I hope this helps. Again Guitar center is best to check first.
THANK YOU, MIKE
Sep 10, 2011 | Audio Players & Recorders
I HAVE TWO SMALL SPEAKERS HOOKED UP TO MY COMPUTER AND I WOULD LIKE TO CONNECT MY LCD SCREEN SPEAKERS TO MY COMPUTER INSTEAD OR IN ADDITION TO THE LITTLE ONES THAT I HAVE THAT HAVE LOW QUALITY SOUND. WHAT...
You can get a line splitter at Radio Shack,WalMart,BestBuy,Compusa etc. Just tell them you need a PC audio line splitter,they'll know what you mean.And they don't cost very much,$3-$4.Radio Shack will be the most expensive.You plug the male end into your audio board,and the male end from each set of speakers into the female end on the splitter.There's a link to a picture below.
If this helps,would you please rate my post?
Thanks
Bob
https://www.cablesforless.com/p-132-stereo-splitter-6-inch-male-35mm-plug-to-2x-female-35mm-plugs.aspx
Aug 19, 2010 | Computers & Internet
How do you hook up an additional set of speakers to this monitor so that I have four speakers working?
You'd need to get a 3.5mm stereo audio jack splitter (aka "headphone jack splitter").
It'll look something like the pictures below.
You should be able to purchase one for a few dollars pretty much anywhere you buy electronics or audio equipment (Radio Shack, Best Buy, etc.).
Once you have that, make sure both your computer and your monitor are turned off.
-Then, unplug the audio cord (that goes from your monitor to your computer) from your computer (you can leave it plugged into the monitor).
-Plug the splitter into your computer where the cord was previously plugged in.
-Next, plug the cord into one of the open jacks on the splitter.
-Plug the audio cable for your *second* set of speakers into the other jack on the splitter.
You should be able to turn on all the devices and have audio coming from all the speakers now.
Let us know if you have more questions!
May 31, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Hooking up 2 additional monitors..
you can try to use a y splitter. the problem with that is the receiver will not give you enough "power" to power up the headrest. You will probably lose picture quality. There are amplifiers that can be purchased that will have extra outputs for video, this would be your best bet. It will give you great picture quality.
May 18, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
Hello. have just experienced the Vizio Pop Of
Replace the Z Sustainer Board, Part # 6871QZH044B and replace the Y Sustainter Board, Part # 6871QYH039B at the same time. If you replace one and not the other the bad one will end up shorting the good one and you’ll lose your picture within a week. You can do this work yourself by unplugging the unit and placing it face down on carpet (put down a soft blanket to protect the screen) and unscrewing the back of the unit (a power screw driver works great for this job because there are a few screws involved). The cheapest place to buy these two parts are: www.discount-merchant.com , orwww.avextra.net, or www.ebay.com There are two additional Y Sustainer supporting Boards called the Upper and Lower Y Boards in the P50HDM that can also be replaced at the time of the Z and Y Replacement. There part numbers are: 6871QDH088A and 6871QDH089A. Although some techies prefer to replace them at the same time as the main Z & Y Boards they probably weren’t the cause of the problem and most likely don’t need to be replaced. However, if you decide to replace them along with the Z & Y then it’s additional insurance that it won’t happen again, plus these boards are actually pretty cheap unlike the Z and Y which are a bit more expensive. It’s also popular to add two additional CPU fans to the unit for additional cooling. Apparently the POD (Pop of Death) has something to do with the main Z and Y overheating. To add additional CPU Fans, which are also pretty cheap, you’ll need a 3 Pin Y-Splitter (M-F) and a 4 Pin Y-Splitter (M-F) for extra plugs to connect to the additional fans but be sure to purchase a super quiet fans since the additional fans will be running along with the two 5 inch super quiet fans that came with the unit.
Apr 15, 2010 | V, Inc. Vizio P50HD Plasma Television
Add more paths to the drum kit
A line splitter I would asume. Some people just by two brains or more and make a really huge set. I would recomend just buying to brains, alot easyer and more options to chose from.
Dec 15, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
HV splitter block bad
If you have the RA-6A chassis, you can find the part if you go to this website.
Nov 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Original problem ...
There are two additional Y Sustainer supporting Boards called the Upper and Lower Y Boards in the P50HDM that can also be replaced at the time of the Z and Y Replacement. There part numbers are: 6871QDH088A and 6871QDH089A. Although some techies prefer to replace them at the same time as the main Z & Y Boards you won't know if they are the problem unless you still have problems after the Z &Y are replaced at the same time. Since these are much cheaper than the Z & Y (about $50 each) that should take care of the blinking.
It sounds like you don't have the dreaded problem of busted panels otherwise you wouldn't have a picture at all. these boards are actually pretty cheap unlike the Z and Y which are a bit more expensive. It’s also popular to add two additional CPU fans to the unit for additional cooling. Apparently the POD (Pop of Death) has something to do with the main Z and Y overheating. To add additional CPU Fans, which are also pretty cheap, you’ll need a 3 Pin Y-Splitter (M-F) for the extra plugs to connect to the additional fans but be sure to purchase a super quiet fans since the additional fans will be running along with the two 5 inch super quiet fans that came with the unit.
Jul 29, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
kawasaki PVS1965 Portable DVD Player Logo
147 people viewed this question
Top kawasaki Televison & Video Experts
Damen Wong
Damen Wong
Jaime Hernandez
Ekse
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
