Question about JVC Car Audio & Video
Jvc Kds88bt Cd Receiver keeps blowing fuses - JVC Car Audio & Video
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Short circuit internally (maybe) or if old units ,u are using an undersize fuse. for old units 10 years above power consumption increases
Posted on Jun 05, 2013
SOURCE:
Keeps blowing a fuse, assume it is bad radio. No fuse will solve it
Something wrong in the power circuit if the cassette cause the fuse to blow everytime. The power circuit should be fixed first then no fuse will be blown
check for short circuit component at the power circuit. Transistor or diode or zener whichever there
May 06, 2015 | MB Quart WR1-CD Nautic Marine...
Fuse on my jvc cd portable system,model. Rd n1 keeps blowing
Fuses blow when there is an overload. It could be caused by a short circuit device in the power supply, but more likely the main power amp device(s) has failed. They will be located on a big heat sink.
Mar 20, 2015 | JVC Audio Players & Recorders
Why does a fuse blow in my JVC receiver Model AX-S331?
usually a crossed speaker wire, or overdriving the amp will cause a fuse to blow
Mar 21, 2013 | JVC Audio Players & Recorders
Can set the time but not save it or display it
i would look at the red assesory wire that is to keep power in your head unit even when the car is shut off it is part of the memory for time, radio stations ext.some have fusable link in red wire,sometimes they blow out like a fuse.can be picked up at radio shack.its a cheap fix if thats what it is.some dont have link in red wire.if thats the case its inside the head unit.it is not keeping power in the unit once the car is shut off.FORGETS EVERYTHING LIKE A 90 YR OLD MAN LOL.PS CHECK ALL CONNECTIONS.good luck
Dec 22, 2010 | JVC KD-AR870 50W x 4 CD/iPod Ready/Sat....
JVC RX 505v stereo receiver keeps blowing fuses. Replaced fuse with specified rating (125v 5 Amp) but still keeps blowing fuse. Fuse appears black inside and I see a flash when I apply power. Can...
The likely cause of this is a dead short in the power supply. I don't receal the specifics of this unit, but there should be a set of four(4) diodes or a single bridge rectifier in the main power supply area. Check this/these for a direct short using a diode checker. Other than that, the output transistors being shorted can cause hte same symptom. Without seeing the actual unit, I can not tell for sure. If you know how, check the output transistors as well. Report your results here.
Dan
Nov 30, 2010 | Audio Players & Recorders
Looking for jvc old receiver model jr-s501
Did you ever find a JVC JR-S501 receiver? I've got one, with a problem. It will play fine for, sometimes half an hour, or sometimes less, and then a loud "POP" sound in speakers. But then will play fine again. Blows fuses on speakers.
Jul 12, 2009 | JVC Audio Players & Recorders
Turn it on and blows fuse replace fuse and plug it in and it blow
You need to have the receiver serviced. The fuse is blowing because some part in the power supply or amplifier section has failed. A service technician will need to troubleshoot the unit to determine what parts need to be replaced.
Jul 10, 2009 | JVC TH-C50 System
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
Blowing fuses
Maybe the audio amplifiers IC are in short circuit or the alimentation board are damaged
Aug 16, 2008 | Audio Players & Recorders
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
