Back to:
Tags:
JVC KT-SR1000 SIRIUS Radio Receiver
Power supply to Sirius Radio
posted by Nudge on Aug 18, 2007
Hi.
I bought a used 2004 used car 1.5 yrs. ago that has a dash mountiung bracket and two wires coming out behind bracket. I know I have a satellite antenna above my windshield. My question is, will a new Sirius radio hook up to this. I tried my friends Sirius Sportster Replay and it worked fine. Do I have to worry about power differences?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 19, 2007
Thanks for Trying (70)
imseth85
Rank:Wiz Wiz
Rating: 85%, 41 votes
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on power supply to Sirius Radio:
I don't want to Accept this solution
Can you Help with these Satellite Radio Receivers problems?
I use a JVC KT-SR1000 receiver docked to a KS-k6002...
At first the unit said it had no antenna.  Then I...
Will the same docking station work for both unit the KT-SR...
when i put unit on it go to 184 and it will not go to...
no cable . do you happen to know what each pin for the...
Loading problems.
Repair Service
Find Satellite Rad. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
