Question about Canon PowerShot A95 Digital Camera
Low battery! My digital camera keeps stating low battery and retracting the lens when completely new batteries are inserted ....can anyone help please thank you Oxed
    Champion:
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 30, 2007
SOURCE:
CAMERA M425 HP PHOTOSMART
use AA duracell batteries with high amps.
that would help you
Sep 16, 2008 | HP Photosmart M425 Digital Camera
Tip
Troubleshoot Non-Retracting Lens Due to Camera Drop
<span>Remove the batteries from your digital camera and leave them out for a few minutes. If you are using rechargeable batteries, make sure the batteries have a full charge before placing them back into the digital camera. It is recommended that you charge the batteries for at least 6 hours. If you are using regular AA or AAA batteries, make sure you are using brand new batteries of the same brand. Turn the camera back on to see if the lens will retract. If that doesn't work, turn the camera back off and try turning it back on while you are pressing the function or OK button.<br />If the batteries were low when the camera was dropped, the lens may not retract properly until the camera is reset. Remove the memory card from your digital camera and install new batteries. Do not put the memory card back into the digital camera and turn the digital camera back on. You will get an error message regarding the memory card, but that is okay. With some digital cameras, leaving the memory card out will trigger a reset within the digital camera.<br /></span><span>If you have an audio/video cable (AV), insert that cable into the digital camera and turn it on. By using an AV cable, the LCD screen will not power on, which means there will be more battery power available to the digital camera. If any dirt got into the digital camera when you dropped it, the extra power may help the camera retract the lens.</span> <span>Place your digital camera on its back on a hard surface. The lens should be pointed towards the ceiling. While pressing the shutter button, turn the digital camera on. The idea behind this concept is that the camera will try to autofocus, which may help seat the lens barrel pins back into their slot.<br /><b><br /></b><br />It is possible that when you dropped your digital camera, dirt, sand particles, etc. may have lodged themselves into the lens barrel. Gently blow around the lens barrel to knock lose any particles. Using a microfiber cloth, wipe off the lens and try to wipe as deep into the lens barrel as you can. You can also try using compressed air and blowing it in the gaps around the lens barrel. Be careful not to blow any of the compressed air onto the lens itself, as the pressure of the air may damage your lens. The idea here is that if there are any particles lodged in the lens barrel by the lens mechanism, you will be able to knock them lose.<br /></span>
on Jun 29, 2011 | Cameras
I have a samsung 860 digital camera ang my problem is the lens... the lens is still retracted even its turned off... before it happened the camera have a low battery.. and when i charged the battery for...
This may be similar to another solution posted. Try heavy duty batteries - I used ACDelco Super Alkaline, but any brand of "heavy duty" AA should work. Make sure battereis are not cold; low temp causes any battery to lose power. If fresh heavy duty batteries do not help, it may need professional service. (DO NOT try to force the lens back to retracted position - something WILL break.)
Dec 18, 2009 | Samsung S860 Digital Camera
Lens comes out, then retracts after charging.
If this camera has a rechargeable battery in it You Will Have to Get a new battery for it(Your Description indicates a Bad Battery Cell). If it uses AA Rechargeable Batteries they will Need to Be Replaced.
May 09, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens is stuck
This happens when the camera is in the ON state and the battery power drains out completely. Please recharge the batteries or insert charged batteries and the lens would get closed automatically.
Please let me know if that works.
Thanks and Regards,
Srinivas
Apr 17, 2009 | Nikon COOLPIX L18 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Canon PowerShot A95 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
