Question about Philips Magnavox 27MS343S 27" TV
Need to degauss a magnavox tv
How do I degauss a Magnavox 27ms343s
  • Shadeau_mex Jan 01, 2008
    please describe how to degauss this model. my tv was in a car accident and now the picture is all streached out and/or warped.
    Welcome Back:
    Visited the website for 2 consecutive days.
Do not put a pm magnet to the screen. That will screw up the screen and give it a rainbow color effect. I use my soldering gun to degauss tv screens. But anything that generates a magnetic field from any power source will do.
Posted on Jun 02, 2012
    Problem Solver:
  • 18 Answers
Why do you think it needs to be degaused? What are the symptoms?
Posted on Aug 19, 2007
I need a code for a magnavox tv please
You have a Magnavox TV and you want to use a universal remote (?) to control it. What brand is the remote?
Dec 17, 2012 | Philips Magnavox 27MS343S 27" TV
I need a remote for my television
This link will assist you with getting a remote that will work with this television.
Mar 29, 2011 | Philips Magnavox 27MS343S 27" TV
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote! What can be done?
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote and it wont turn on although the powered up red lighht is on. Tv has been reset to sleep mode by universal remote. What can be done?
Feb 01, 2011 | Philips Magnavox 27MS343S 27" TV
I have a blue -green color at the bottom of my Magnavox 27 inch/ Model 27MS343S screen. What do I do?????
Ir is due to the magnatization of the picture tube. there are tw main possibilities for this fault. The first one is , if you place any high intensity magnetic materials, like stereo speaker boxes, which contain high power magnets inside on speakes or so on. The second one is failure of degaussing posistor inside the circuit board of your Tv.
Every colur TVs has this posistor, ususlly called degaussing posistor, which will work each time you switch on your TV by AC mains, for a very little , say to some microseconds or so, and it will heat up then and its resistance will go up to infinite, not allow any current to pass through. It is connected to a coil fitted around the picture tube inside, and will demagnatize the picture tube each time you switch on the Tv. If you switch off regularly with remote control, this posistor will not work, as there will not full power off occurs.
Do one thing first. Switch off your TV with it front panel power ON/OFF swtich, or unplug it from the mains wall socket for some time, say 30 minutes or so, and the switch it on. In rare occations this will retify the problem. If not, replace the degaussing posistor with an identical type. OK.
Jan 06, 2011 | Philips Magnavox 27MS343S 27" TV
Impurities on screen. Looks like old crt problem
It could very well be it needs de-gaussed or possibly the PTC in the TV which de-magnetises the screen may be faulty. In the worst case the shadowmask part of the TV could be at fault which would mean replacing the CRT
Nov 04, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 20mt4405/17 piece of junk!
Hello sletak, This problem is actually common. Your degaussing coil has malfunctioned, causing the power supply to become unstable which in trun is effecting the memory settings in the processor. You have threen problems in one so lets start by looking at the overall cause first 1) degaussing coil going bad (shorted then opened) Replace this and the thermistor that is attached to the degaussing circuitry. 2) power supply instability (power surge from the degaussing circuit) replace the damaged components in the power supply section. Troubleshoot this thoroughly. 3) after fixing the power supply and the degaussing components you will need to manually degauss the TV and then use the auto-degaussing function to do the rest. I hope this helps, Thank you, Shuttle83
Jun 10, 2009 | Philips Magnavox 20MS233S 20" TV
Magnavox 27ms343s tv won't turn on manually or with remote, help
If you are comfortable with tool sthere is a fuse inside the unit right where the plug goes in. I would check this first. Caution unplug it first VERY high voltage inside 30,000 volts!!!
Mar 24, 2009 | Philips Magnavox 27MS343S 27" TV
Some of the color in my tv is not working
u just need to degauss ur TV. Either ur earthing is not proper or there is a magentic source (such as speaker/stabilizer/ups etc) which is not properly shielded. Next time take care of it.
Oct 08, 2008 | Philips Magnavox 27MS343S 27" TV
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
457 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
