Question about Bose & Wave& Music System
Nissan Pathfinder Bose CD Player PN-2121N Volume Knob Broken
My volume knob only worked some of the time and it would make the volume go really loud or soft. I found a replacement volume knob encoder at mouser.com part number EC12E2424407 from ALPS (cost about 3 dollars). Unfortunately the stock volume knob didn't work with it so I had to pick up a 1" knob at RadioShack for 3 dollars. You could also use a dremel and some epoxy to make the stock knob work if you wanted to. You need a soldering iron, solder, flux (optional but recommended) and an assortment of phillips screwdrivers. Disassembling the unit takes a bit of time since the screws are really tight and small. The front black plastic control buttons/piece needs to be pulled off from the front and then disassembled to get to the volume knob. I also had a problem with the cassette eject the found where a metal gear stripped a plastic gear. I cut the motor wire to solve that problem, since I don't have any cassette tapes. Hope this helps Goodluck!
SOURCE:
  • 30 Answers
SOURCE: eer 2 message on bose 6 cd player on 2001 pathfinder
you may need bose qualified serviceman to erase the error,you may need a software from bose.
Posted on Jan 27, 2007
SOURCE: Multi cd bose player will not eject 4th cd.
I have unplugged and disconnected the two pieces of equipment and then set up again several times. Following the "picture" instructions sheet: plugged in the two connections between the units, and then plugged the electrical cord into the unit and then into the wall. Inserted the Bose disk provided, into the Music System unit (on top), it did it's thing and automatically ejected the cd. Still, the disk will not eject. the disks that are "stuck" --now in slots 2 and 4 (#3 actually popped out during one of my many attempts at hitting the "eject" button!--oh wow)--are possibly not allowing the system to setup properly-don't know. Have contacted (email)Bose and waiting for reply...I also will be eligible to retire at age 62 in two years, so which will happen first, reply or ...
Sign me dumbfounded by my own dumbness at having purchased another Bose system in one lifetime.
Posted on Dec 26, 2007
  • 38 Answers
SOURCE: Stuck CD cassette
Dear needhelp5246,
What you need is a screw driver not a sledgehammer. Open the bottom plate of the system and eject the cd magazine manually. Hope this solve your problem.
ramesh22
Posted on Jun 15, 2008
SOURCE: CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Posted on Nov 02, 2008
    SOURCE: No sound
    I had the exact same problem. I disconnected the radio from the power cord in the back, waited several minutes, reconnected the power cord and my radio had sound!!
    Posted on Nov 16, 2008
    Volume doesn't work on bose radio in car all the time
    Sue,
    I had the same issue with a car I owned and had to replace the unit.
    May 04, 2017 | 2009 Nissan Rogue
    How do I fix the volume switch/knob? (CY290)
    Take the radio out then take apart radio and clean volume potentiometer with electrical cleaner from radio shack. Or just change out radio.
    Mar 04, 2010 | 2001 Nissan Sentra
    The volume control does not go up or down when I turn the knob. I have to play around with it and sometimes it works and other times it dosen't.
    On volume control potentiometer carbon layer wears out with time. The easiest way would be to clean it with spirit. Turn off the unit, remove the knob, spray spirit on volume control then turn the knob back and forth around a minute, should work after. Also you can disassemble CD player and resolder pot contacts on the board, when pressure constantly applied from outside, contacts get loosen. And the best way will be to replace the pot.
    Oct 30, 2009 | Alpine CDM-7874 CD Player
    Turned on loud feature need to turn it off
    Press the source button, press the volume knob for at least second, then press the volume button again, and then turn the volume knob and it it will scoll through the adjustments, the last one should be loud and press the volume button again to select off, press and hold for at least one second until it returns to the main screen, then you should be set
    May 12, 2009 | Kenwood DPX-301 CD Player
    No volume control
    lower the volume of the cd player
    May 08, 2009 | NAD C320 2-Channel Amplifier
    The knob is malfunctioning
    The flex that controls the volume on it is broken it is a strip that has wires to it.
    Apr 23, 2009 | Dual XDMR7710 CD Player
    1997 bose volume
    While radio is turned off spray electronic contact cleaner behind volume knob while rotating knob . Make sure you have rag handy .
    Mar 15, 2009 | 1997 Nissan Maxima
    How do i turn off the "loud" option
    hold down the volume knob then hpf will come up then press control knob till you get to loud setting and spin knob it will change to off
    Apr 07, 2008 | Kenwood KDC-X589 CD Player
    Stereo volume doesn't effect Aux input volume
    in a car stereo system, when you select line input, it usually assumes the device you are connecting has its own volume control. if you really want to use your cars volume knob, an FM transmitter might do the trick.
    Nov 03, 2007 | Jensen MP7610 CD Player
    Bose & Wave& Music System Logo
    844 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Steve Allison
    Steve Allison
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
