Question about Garmin Nuvi 660 GPS Receiver
Bluetooth connetion with Verizon Treo 700P
The unit disconnects my phone. Sometimes the phone will reboot and operate normally. Most of the time it will continue to disconnect or cause my phone to freeze up. Downloading latest Garmin Bluetooth and Verizon Bluetooth software does not help. Other people I know have this problem but nobody talks about a solution.
  • FrankieD Aug 24, 2007
    Thanks. Unfortunately, this may be an impossible situation. I did download the latest Verizon-Palm software. No help. The Treo combines the handsfree and headset devices so I can't separate them. I have deleted and reinstalled the Nuvi many times as a nearby, trusted device but the problem persists, disonnecting and freezing the phone. The funny thing is that it occasionally works and the old Garmin software works better than the upgraded software, often only disconnecting and rebooting the phone once. Any other thoughts would be greatly appreciated.
    Novelist:
    Scholar:
  • 114 Answers
Looks like your saying you've updated your n?vi 660 to software(firmware) version 2.0, if so you're moving in the right direction. Unfortunately the n?vi 660 does support the Treo 700P but only seems to support the 'Hands-free' BlueTooth profile and this is often problematical as is the 'headset' profile with some device combinations, that's precisely why many phones and devices now support both profiles. Check the pairing information to see if you're using 'headset' or 'Hands-free', whatever you're using delete the pairing on both devices and see if they will let you pair in the other profile. Your Treo 700P is made by PalmOne (www.palm.com) so you may want to check for software updates from them. This kind of problem is down to the lack of a solid standard for BlueTooth communications and you will often find that settings that work for one combination of devices are unstable with another. Post back if this doesn't help or if you need us to clarify anything.
Posted on Aug 23, 2007
  • 1 more comment
  • Anonymous Aug 24, 2007
    After a full day researching this problem I can safely say it is a known issue neither Palm nor Garmin (or anyone in the Palm community for that matter) has resolved yet.
    The problem stems from the use of the wrong BlueTooth profile and as you pointed out Palm BlueTooth manager has no option to change profiles. BlueTooth data communication/PIM sync between these 2 devises is known to work OK but that uses a separate profile altogether.
    At this point there is no resolution to this issue, if anyone reading this is a developer/programer and has a copy of the Palm BlueTooth SDK can you please write a profile manager app, I think you'll find there's a demand for it.
    One advantage to using palm is that there are lots of programers out there who write Palm applications for fun and when people request them. You stated in your first post that you know other people with the same issue so get together and post requests for help with this issue as possible, the more this issue gets seen the more chance you have of someone writing an app to resolve the problem and of embracing Palm or Garmin or both in to providing a resolution.
    In any contact with Garmin be sure to point out that there web-site claims the Nuvi 660 supports the Treo 700p and this could be considered to be false advertising.
    In communication with Palm explain that although there BlueTooth stack supports both headset and handsfree you have no option to change between the 2.
    On the forums ask if anyone can write/has written any applications to resolve this issue.
    I'm very sorry that there is no way to help you further at this point but if anything changes or a solution appears I will post it here.
    The only thing I can suggest at this point is:
    1: Post requests to Garmin support www8.garmin.com/contactUs/techSupport.jsp
    2: Post requests to Palm Verizon support www.palm.com/us/support/contact/carrier_forward/verizon_forward
    3: post requests to as many Palm forms such as forums.palm.com/palm/board?board.id=bluetooth_and_wifi and GPS forums such ashttp://www.gps-data-team.com/pda-gps-nav... as possible.
SOURCE:
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Cannot get on the web
Which model, The 700wx, 700w, or 700p?
Which Carrier? If other than the 700w (in which case your carrier would be Verizon) then which of the
following carriers do you use: [700wx] Alltel, Bell, Tellus, Verizon or Sprint, [700x] Alltel, Bell, Tellus, Verizon or Sprint, Cellular South?
Take it to your provider and have it activated for Web Enabled Services.
Apr 08, 2009 | Palm Treo 700p Smartphone
Bluetooth synching of a toyota prius and a treo
i had the same problem with a palm 700wx and the new pre try using 1111 as the code it worked for me
Oct 10, 2008 | 2007 Toyota Prius
GE Bluetooth Telephone Adaptor
There is an undocumented solution to link difficult devices. Instead of pushing ad releasing, hold either button down until you get a FAST BLINK and then try linking again.
Jun 29, 2008 | GE Bluetooth In-ear Headset Wireless...
Palm Treo 700P In Death Spiral
I just encountered exactly the same issue.
Was using the phone ended the call and was about to place a call when it started the Death Spiral.
All reset options have no effect. Putting the battery in while holding the sync button will produce a color pattern but no functions are available.
I did call Palm USA tech support - apparently they are aware of the issue but have no free solution that they would offer me - for $199 I could send it to them for repair.
Mar 13, 2008 | RIM BlackBerry Pearl 8100
Pairing a Motorola H850 to A Lg5300 cell
hi
turn on your hands free device. find "connectivity" in settings on your phone. then "bluetooth link". then "hands-free". turn on bluetooth. look for devices. pair from there.
that should do it.
dave.
Dec 02, 2007 | Nokia 6233 Cellular Phone
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Nonworking keys on Treo 700p
make sure first of all that there arent any screws missing or loose in the back by removing the battery cover....thats can cause the keypad buttons to not have a good connection to circuit board... if thats ok then you can use a toothbrush and some alcohol (denatured alcohol if possible) to rub and clean the keypad. If all that fails, I know that Sprint offers repair for their phones.
Treo 700p stuck in network search...T
Verizon suggested a hard reset on my 700w for the same problem. (Hit soft reset and power/end button at same time and hit up on keypad when prompted to reset everything and reboot)
you will loose all of your features but they say it fixes 5/10 times...
It did not work for me but I wanted to share in case.
Oct 26, 2007 | Palm Treo 650 Handheld
Garmin Nuvi 660 GPS Receiver Logo
76 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
