Question about Whirlpool GGW9200L Gas Dryer
MODEL: GEW9200LQ0 Electric Dryer
My dryer turns and operates but it doesn't get hot. Is there a part I can purchase and simply replace myself or do I need to pay $65. for a repair guy to come out to my house and tell me what the problem is and pay even more to have him fix the heating problem? I purchased my dryer in 3/2004 and used it for a year... it's been in storage ever since and I just now moved it back into my home to use it again. HELP???!! Please. JULIE
  • 1 more comment
  • Julie Shoemo
    Julie Shoemo Aug 18, 2007
    ME & MY FRIEND
  • Julie Shoemo
    My friend Dorothy & myself (on the right) :-)
  • Julie Shoemo
    Julie Shoemo Aug 19, 2007
    Thanks for you response :-) Actually I knew I the dryer wasn't getting hot before I moved it out of my last home (before putting it in storage)- I didn't worry about getting it fixed until just now since it's out of storage and in my new home. I haven't even tried to turn it on as of yet- figured I'd fix the "heating" problem before trying. I'm willing to check if you have the time :-) THANKS KRAZYTEC
  • 725 Answers
OK, I would go ahead and try it at this house you my just get lucky!! To check it out you will need a nut driver and a multimeter...alos it is GEW9200LQ0 Electric Dryer and not a gas dryer... let me know and I can help you..
Posted on Aug 19, 2007
  • 3 Answers
Has it ever work at this house? the first thing to check is the voltage and the pig tail .. let me know if you are willing to check it.. and I will help..
SOURCE:
Dryer will heat up then shut off
Most likely it's getting to hot, check your vent and the outside vent hood make sure you have proper air flow. Turn on the dryer check the vent exit to make sure you feel hot air coming out. Take the vent off and check the back of the dryer for air flow. If you have air flow and the unit is still over heating you may need to replace the operating Thermostat. Could tell you more with a good model number should be inside the door.
I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
Oct 26, 2013 | Kenmore 62602 Electric Dryer
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Frigidare dryer aeq6000es2 doesn't spin, humming noise, burning smell
Hello tancrbtt - It sounds like your unit may have one or more problems. Either the belt slipped off the idle pulley and/or dryer belt and needs replacing, a faulty motor or a common failure between control and motor. Consult a professional to accurately diagnosis the dryer and to assist with the repairs.
Feb 12, 2013 | Frigidaire Electric Dryer
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Our dryer doesn't dry clothes like it should, sometimes takes a long long time and other times quick and the clothes feel really hot, model # is DLE 2532W
see this causes and fix it. God bless you
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating Element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. The proper ohm reading can be found in the service manual or sometimes on the tech sheet located somewhere on your dryer (9- 13 ohms is a common reading). Electric heating elements aren't repairable. The heating element is easy to replace. Check our videos for other types of dryer heating elements.
Thermal fuse / Thermal Cut Out / Thermistor
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel or behind the front cover. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing They are also round and made of metal and plastic. The thermistor is located on the blower housing usually. If any of the fuses do not have continuity replace it. Check for continuity if none replace, But before replacing check for obstructions. The fuses are very inexpensive and easy to replace.
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. Check all connections, make sure they are tight. Loose connections can lead to a fire. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Sep 27, 2012 | LG DLE2532W Electric Dryer
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer spins but doesn't get hot. Model #11077522600
heatman101
Sep 09, 2011 | Kenmore 73952 Gas Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
My dryer is running hot but doesn't dry the
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Whirlpool GGW9200L Gas Dryer Logo
391 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
