Question about Onkyo TX-DS696 Receiver
The remote control dosn't work! - Onkyo TX-DS696 Receiver
I had to remove the batteries of the remote control.
Having done that, the remote control has been reinitialized and worked again perfectly.
Posted on Nov 11, 2007
SOURCE:
How do I GET A new remote
You may be able to sustitute an RCA universal remote that will work.
Oct 02, 2014 | RCA New Original DTA800B1 Remote Control
Remote key dosn't work till you are very close on my 1999 Mercedes C230
not much if battery changed the key fobs a notorious for going and very expensive to replace about 200 pounds as long as its still working don't worry about it
Mar 19, 2013 | 1999 Mercedes-Benz C-Class
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
Fan blower fuse location on a ford f150 year 2000
FUSE #105 40A** Climate Control Front Blower, THIS FUSE IS LOCATED IN THE UNDERHOOD POWER DISTRIBUTIOPN BOX
Oct 14, 2009 | 2000 Ford F150 Flareside SuperCab
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
Tv remote dosn"t work
Check with new battries, and if you have a camera phone you could see the front IR bulb lighting up when seen through the phone display. Patrick
Jun 16, 2007 | Symphonic ST419E TV
Onkyo TX-DS696 Receiver Logo
103 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
