Question about Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Dishwasher
Bosch dishwasher SHX33A
Very loud noise during draining cycle, cleaned all traps and arms, works fine in cleaning dishes, just sounds like its gonna take off when draining throgh out the cycle's other then that its quite.
  • 1 more comment
  • murph712 Aug 24, 2007
    Where is the inlet valve on my dishwasher?
  • Anonymous Mar 12, 2014
    Dishwasher powers/churns/drains but will not run cycle and within minutes of starting beeps that the dishes are clean. I have tried every reset option I can try. I have turned the electricity off at the breaker for 5 minutes and turned back on...no luck getting a dishwasher cycle to run. Dishwasher ran fine until the problem. The unit has not been moved so do not think it is a kink in the hose, etc.
  • Anonymous Mar 26, 2014
    all cycles work correctly, dishes are clean, water is drained at end of cycle, nothing clogging the drain
Dishes and glass have film on them
Posted on May 29, 2008
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Posted on Sep 20, 2007
Hotpoint Aquarius dishwasher making awful rumble/crackle noise
Have you cleaned the traps and run some vinegar through? They build up dirt from kitchen debris over time which causes the pump and spray rails to pick up sludge. You need to clean them at least every 6 months. Check farther on line for cleaning solutions to clean and maintain dishwashers. I have been hearing clr can be used but can't confirm this.
Oct 23, 2017 | Dishwashers
My Bosch SHX56BO6UC14 is not getting the dishes clean at all. It's making a grinding sound. It is pumping water & spraying water, but not getting anything clean. help?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 09, 2011 | Bosch Dishwashers
We have a Bosch dishwasher...model #shu4326UC. We have been so happy with it until recently. All of a sudden the dishes are not cleaned properly. We have to run the cycles a couple of times and are...
You likely have food or soap buildup stuck behind the trap in and around the drain workings. The only remedy it to remove the trap cover or lower arm assembly, and start poking around. The food finds its way into the tiniest of places and sits there, but it dirties up the rinse cycle. I have to clean mine out about once per year.
Nov 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
LG Dishwasher LD-1403W - loud whirring noise during wash
We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
Jan 01, 2010 | LG Dishwashers
Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Sep 18, 2009 | Bosch 24 in. SHX46B05 Stainless Steel...
Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 06, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Open Questions:
See all Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Questions
Bosch 24 in. SHX33A02 / SHX33A06 Free-standing Dishwasher Logo
891 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
