Question about Canon CanoScan LiDE 600F Flatbed Scanner
Light stripe on scans
Im only scanning in black and white, when i do so theres a stripe right of center that is alot lighter than the rest of the image. there doesnt appear to be any mark in the scanner glass and it looks like the stripe is in the same position as the metal rod inside the scanner along which the scanner head travels. can anyone help?
    New Friend:
I have a Canon Lide 25 and I had a thin black stripe with a fat rainbow stripe in color mode and a bright light in grayscale mode.
I use canon scan toolbox, I checked the box for "display the scanner driver", in the advanced mode tab find calibration and click on execute.
If you have a different Canon scanner with a different software, look for calibration or adjustment.
Posted on Jun 27, 2012
  • 20 Answers
Possible causes, CCD failure, smudges or marks that can only be picked up by the CCD if the underside of the scanner glass is dirty. Uninstalling/reinstalling your scanner driver will eliminate if its software related or not. From the looks of it, could be with the CCD if the lines are in the same area with every scan attempted.
Posted on Aug 29, 2007
SOURCE:
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Wiring in a sony CDX-L600X in a 95' F150
red is B+
black is ground
dark blue with white stripe is remote for amp
blue is power antenna
yellow is ignition
white and white with black stripe is front left
gray and gray with black stripe is front right
green and green with black stripe is back left
purple and purple with black stripe is back right
this is for the deck
Mar 21, 2010 | Sony CDX-L600X CD Player
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Im lookin fer the radio wiring diagram for my 1996 geo prizm because someone cut the standard clip for the stock radio out
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C Right Front Speaker (-) Blue Gray w/ Black Stripe
D Left Front Speaker (-) Purple White w/ Black Stripe
E Ground Wire Black Black
F +12 Volt Ignition Wire Gray Red
G Power Antenna Wire 1 Blue (join wires 1 & 2
H Power Antenna Wire 2 together to this blue wire)
I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple
K Right Rear Speaker (-) White Purple w/ Black Stripe
L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
M Left Rear Speaker (+) Black Green
N Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 02, 2009 | 1996 Geo Prizm
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Im installing a new sterio in a 95 mustang ----i need a colour code dia. of the wires on the old factory sterio. Which wire goes where?
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Jun 17, 2009 | 1995 Ford Mustang
PIONEER SUPERTUNER 3 KEH-P4200
tdohnke-So you need a wiring diagram,well lets see what we got
red-accessory-12volt key switched
orange-12volt constant-memory
black-ground
white-left front speaker-positive
white with black stripe-left front speaker negative
grey-right front speaker-pos.-
grey w/black stripe-right front-neg.
green-left rear-pos.
green w/black stripe-left rear-neg
purple-right rear-pos.
purple w/black stripe-right rear-neg.
blue- remote turn on
orange w/white stripe-dimmer-optional
Try out this diagram,they are pretty much all the same now,if I missed any let me know. cooltek Mar,4/08
Mar 04, 2008 | Audio Players & Recorders
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
502 people viewed this question
Clive
Clive
old marine
old marine
Ekse
