Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Loud noise and lots of ice buildup in freezer
Help! I have a GE TFX24V but couldn't fint it in the list. Anyway...my freezer is making a loud constantly-running noise and is also caked up with ice. Water was on my floor this am. Anything I can do myself...or do I have to wait til Monday for a service call?
  • 183 Answers
Possible that door has been left open a few weeks ago, sollution, turn off defrost overnight with the doors open, turn on following day, unit will work ok within 24hrs. Regards Advisor
Posted on Aug 23, 2007
2 Suggested Answers
SOURCE:
  • 183 Answers
SOURCE: Loud noise in freezer & ice buildup, too
Turn off, defrost over night doors open turn back on will work ok Regards Advisor
Freezer side is making an extremely loud humming sound. Ice maker is working fine. No ice buildup anywhere in the freezer that we can see. Loud humming goes on for a few minutes each hour.
Hey Joanne, I appreciate your inquiry!
Based off my understanding the freezer side of your Frigidaire refrigerator is making a loud humming noise. The humming sound could be coming from your compressor. If the sound is a new development it may be a possible issue with the fan pushing further against the wall. You may need to seek help from a professional technician for proper diagnosis and repair. This will help you from purchasing any unnecessary parts. Hope this information is helpful to you. -Matt
Dec 30, 2015 | Frigidaire FRS23W3A Side by Side...
Have a loud humming noise
You probable have ice buildup around your evaporator fan. You would need to remove the evaporator cover inside the freezer to expose the fan and see if you have ice around it.
Mar 13, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a Danby DUF1596WE standing freezer. There is ice build up on the back wall. The fan is making a very loud noise. The freezer is still working. I had to shut it off due to the loud noise.
The chances are that the ice buildup is now in contact with the fan, hence the noise when fan hits ice.
As a short term fix, power the freezer off and let it defrost naturally, this will cure the immediate problem. In the long term, I presume that this is a self defrosting freezer, so you appear to have aproblem with the defrost cycle. You MAY find that a long power off and defrost will cause things to reset and it may well cure your problem anyway
Jul 05, 2011 | Microwave Ovens
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge Motor Super Loud
Open the freezer door and see if the sound is there or if its near the floor. This needs to be corrected soon to prevent damage to your refrigerator. Your explanation makes be think the fan inside the freezer is loose or has ice buildup around the blades or the fan blade has become unbalanced in some way...Let me know and please rate me, Thanks, Sea Breeze
Jul 14, 2009 | GE Refrigerators
Ge monogram ice maker makes loud churning noise. Any suggestions
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Jun 12, 2009 | GE Monogram ZDI15C Automatic Icemaker
Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
Jun 04, 2009 | GE GSS25JEMWW Side by Side
Ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop ice buildup internally, especially if the air vents at the back of the freezer are blocked by frozen food. Once that happens, that ice can interfere with the cold air circulation booster fan that runs when the freezer temperature is too warm. Then you get a LOUD buzzing noise from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the fan. You can turn the fridge off for a while (with the food removed so it doesn't spoil), and/or get a hair dryer and heat the inside back of the freezer, until the ice melts and falls away from the fan. (Just be careful not to block the nozzle of the hair dryer, or it may burn out from overheating!)
But the ultimate solution is to buy another refrigerator, one that is NOT a GE! And that makes me sad, because GE used to make GREAT refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
May 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
146 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
