SOURCE: When using Navman in my
that's because your using GPS signal that is constantly resetting itself and it uses battery life to do so, GPS uses more energy than anything else the iphone will do. If your still within hardware warranty call Apple and they might help you with it
SOURCE: my Iphone was working fine
I know how desparate this feels - try powering it off completely and remove / replace the battery - make sure the charger is connected securely and try again - you should be able to use the phone whilst it is on charge. If the charging symbol does not appear when in charge mode then the charger itself may be faulty. Try hooking it up to a USB cable from your PC - it should still charge but not as quickly.
Testimonial: "great thanks!"
SOURCE: battery life on iPhone 4s
mine used to go dead quick try getting a new battrey if you can but that might not fix it.
