Question about Kenmore 95087 Gas Dryer
Dryer will not get hot.
The dryer rotates and comes on, but will not get hot. It is a gas heater. I checked the 3 sensors and they all have continuity.
  • 164 Answers
Th problem could be either the globar igniter or your gas valves. first disconnect the machine and then remove the front panel. the globar is the ceramic piece at the end of the gas valve. visually inspect it for any cracks. if its cracked replace it. if its not cracked remove the plug from the globar and using a volt meter check at the plug for continuity. if you have continuity go to your parts store and get a set of gas coils ( its a common part interchangeable for most brands) replace coils and that should do it
Posted on Aug 20, 2007
Where is thermostat located on ge dryer,starts hot then it gets cool
Dryer possibly overheating due to plugged vent. They will go into a safe mode and shutdown the heater if not enough airflow. Results in starting hot but ending with a cold load of clothes! Check the belt to ensure the dryer fan is working and that the drum is properly rotating. If OK and the vent is clear then check the thermostat. Depengin on the type (Gas vs electric) there are a number of limit thermostats as well as a main thermostat. Likely you have a a limit switch kicking in to shut off the heater. Normally from lack of airflow (plugged vent, fan broken, etc...) Once unit cools down will start back up but shut down again once the heater comes on. Also check to see if the heating element is shorted to the side of the metal case. Will heat up and be intermittent.
Jun 10, 2014 | Dryers
My dryer still rotates but it does not blow hot air and it contineously rotates.the only way it will stop is if Iopen the door
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 13, 2010 | Estate TEDX640JQ Electric Dryer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Dryer runs but heater dosent come on
if your apliance is gas dryer you need chek:
1-thermal fuse.
2-sensor flame.
3 ignitor.
gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 07, 2009 | Maytag Dryers
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
There is a glow bar that ignites the burner. The glow bar probably needs replacing, check it with an ohm meter, usually you can see if the glow bar is broken because it is ceramic and is usually broken. Be carefull when replacing the new one not to touch the part that glows
Jan 09, 2009 | Roper REX4634KQ Electric Dryer
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Kenmore dryer doesn't get hot but drum rotates fine
I read on another page
1) One of the thermostats could have a reset switch on it to cure problem... do not know where to find it or what it looks like! ....
2) May need to replace the element...
3) Could be the exhaust thermostat / or heater and thermostat complete/ check continuity...should be normally closed(complete circuit)
Any help to you ????
Best wishes willow
Mar 13, 2008 | Dryers
Kenmore 95087 Gas Dryer Logo
64 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
