Question about Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
Hi, There are 2 problems at present. When recording an image, the zooming mechanism (the button that indicates: "T - W")zooms into the image very slowly. How do you stop it from zooming in when recording? The playback icon symbol shows in the viewing screen and playback starts happening when pressing the rewind button. The stop, pause, fast forward buttons are non fuctional when this occurs. The only way to stop the playback is pushing the eject button or turning off the power button. Rewinding a tape is not fuctional at all. The zoom button still operates when recording but is stuck slowly zooming in all the time. Pressing in the Play button will not start playback but pressing in the Rewind button will start playback. Power off or eject to stop playback. Pressing the Pause button will start playback. Power off or eject to stop playback. The Zoom, Rewind and Pause buttons are all that are functional in Player mode operating as described. Recording "seems" to be happening with the Zomm function slowly happening all the time. We can't be sure recording is happening though as we can't rewind the tape to playback and see.
  • 6 more comments
  • jstasney Aug 18, 2007
    The above comment sentence that reads:
    "Recording "seems" to be happening with the Zomm function slowly happening all the time."
    Should read:
    "Recording "seems" to be happening with the Zoom function slowly happening all the time."
    Also, there are no Error codes displayed on the LCD viewer.
    The camera has had the battery removed and been allowed to
    re-initialize after 30 seconds of removal as per trouble shooting proceedure recommended @ Sony.com.
    Sony.com recommends we send it to them for servicing repair as there are no service centers in our area registered with them.
    Thanks again for your time in this matter.
    <>< JLS
  • jstasney Aug 19, 2007
    Do you have dis-assembly detailed instructions with detailed pictures...your saying re-solder the connections, right?
    I can do that....if that is the problem...time will tell..
    Accepting all posts...the more the merrier...
    Knowledge will forever govern ignorance; and a people who mean to be their own governors must arm themselves with the power which knowledge gives.
    ~ James Madison ~
    The original comment line that reads:
    "The stop, pause, fast forward buttons are non fuctional when this occurs."
    This line should read: "The stop, pause, fast forward buttons are non functional when this occurs."
    Sorry for the spelling error.
    <>< JLS
  • jstasney Aug 20, 2007
    Sounds like a plan.
    I'll wait for the illustrations though. How many cabinet screws are we talking and are we talking LCD side only? I can edit and enclose a .jpg(s) of the camera in Microsoft Paint for clarity if needed. Lets make our instructions step by baby step if you don't mind here. I'll be a virgin on this. Oh my!
    <>< JLS
  • jstasney Aug 22, 2007
    Hi Magic,
    Resin flux, hummm, I might have to get that.
    Whoa, that picture sure looks intimidating, huh? I sure hope nuttin' plastic snaps off.
    Got any tips on the where abouts of those front assembly claws that snap into the side cabinet that need a little encouragement to let go?? That'll make the pry points at the proper place needed.
    Those are some good virgin instructions, by the way. Well versed for a beginner. AND well appreciated.
    Thanks
    Regards
    <>< JLS
  • jstasney Aug 23, 2007
    Ah, it's nice to know where that elusive front cabinet is, I would have thought the lens was the front.
    Imagine that?
    OK, well try that when we get all these duckys in a row....supplies and such...
    <>< JLS
  • jstasney Sep 03, 2007
    I'll maybe get to attempt this repair this week. I pooped from bird hunting right now.
    Thanks for the additional comment.
    <>< JLS
    Genius:
  • 1,153 Answers
I noticed on mine, I had to use small amounts of compressed air to stop it from focusing slow. Dust will do this, It has a small motor and it could be dirt slowing it down. Sounds like display problems also.
Posted on Sep 08, 2007
  • 38 Answers
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Posted on Aug 19, 2007
  • 3 more comments
  • Mike Beale
    Mike Beale Aug 20, 2007
    I will attempt to get you an illustration tommorrow. Disassembly entails removing all the cabinet screws marked with an arrow. You will need to remove the battery compartment from the rear to access the cable connector, but only after removing the side cabinet with the lcd, front ass'y snaps out first. No need to remove the screws from the lcd frame which are marked with arrows.
    More later,
    magic seadog
  • Mike Beale
    Mike Beale Aug 21, 2007
    1. Remove 6 screws on the bottom.
    2. Rmove 2 screws, top front and remove the front corner part.
    3. Remove 3 screws top front and top of cabinet.
    4. remove 3 screws at the rear; top left battery compartment,
    below the exposure batton and above the start/stop switch.
    Now you may proceed to pull the front assembly forward, it has some claws that snap into the side cabinet that need a little encouragement to let go. Don't be concerned if the fpc cable comes loose, it will plug back in OK. Everything else slips apart to appear as the attached photo. The connector of concern is on the board pointed out in the photo labeled EJ-30 and comes off with 2 screws. There are 3 different fpc cables connected. The top operation cable is obvious. It usually is simplest to apply some flux and reaffirm the solder joints rather than applying new solder which is difficult to control with very small tolerance. That is your choice. Always clean up with isopropyl alchohol or flux remover of some kind.
    Good luck,
    magic seadog
  • Mike Beale
    Good luck,
    magic seadog
  • Mike Beale
    Mike Beale Aug 22, 2007
    If you grasp the front cabinet and pull in the direction of the selector switch (Japanese refer to this as the right side as you face the lens) the claws will let go OK. I've never broken one.
    Sincerely,
    MS
  • Mike Beale
    Mike Beale Aug 31, 2007
    I,m afraid that the photo and the explaination were confusing. You're right, the front cabinet is where the lens is. And the explanation pertained to that. The photo is the end result of having the unit disassembled to the point of exposing the part in need of repair which is the small board that is pointed out. Two screws hold it in place.
    Take care,
    ms
SOURCE:
Sony Handycam CCD-TRV107E Hi-8 Analog Camcorder When I turn the camera on to record, It will record audio, but the screen stays black, as if the lens cap is really on.
CCD Failure !
but u are entitled for free repairs from Sony just call them it is a known problem
http://www.sony-asia.com/support/announcement/45536/product/ccd-trv107e
pls rate me Fixya for help
Apr 20, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
I have a Sony Video8 Handycam CCD TRV211.
If you are asking about CCD-TRV211 camcorder?
CCD-TRV211 is analog Video-8 camcorder so its movie data is not digital and can not be connected directly with computer via USB port.
Best and easiest was is to connect camera with DVD Recorder and burn DVD, this will convert analog movie file into digital data and you can copy it to hard disk of computer.
Mar 31, 2009 | Sony Handycam CCD-TRV308 Camcorder
Black screen
It is known problem of bad ccd imager in camcorder and requires replacement of that part.
Sony will repair CCD-TRV318 Free of Cost in ccd imager problem.
Please click Sony CCD Imager Support for details.
Good luck.
Feb 01, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam Vision videoHi8 will record sound, but no picture.
Good luck.
Jan 27, 2009 | Sony Handycam CCD-TRV318 Camcorder
There is no picure in my view finder or LCD screen. I have all of my display menu's and such, but no picture, and yes the lense cover is down. There is a small eye looking icon in the screen, and I can...
Its known issue of bad CCD imager in DCR-HC30 and CCD imager will be replaced.
Sony will repair your handycam free of cost as per announced scheme of CCD problems.
Click on Sony CCD Support for details.
Jan 12, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Oct 23, 2008 | Sony Handycam DCR-TRV140E Digital...
Handycam says C:31:22
error 31:22 means camera mechanism has error in take-up reel section and micro processor isn't receiving reel signal so it shuts down playback/ record function immediately. look into take-up reel section of mechanism.
Sep 11, 2008 | Sony Handycam CCD-TRV308 Camcorder
SONY CAMCORDER CCD TRV 328 rec,problem
Your camera ccd-TRV328 has defect with ccd imager that's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Sep 02, 2008 | Sony Handycam CCD-TRV328 Camcorder
How to copy a Hi 8 tape to a DVD on a computer
Sony handycam model starts with CCD-XXXX shows that its analog camcorder and its picture signal is analog. You can't connect directly camera with PC to transfer files. You need to install MPEG card or some thing like that in PC 1st and this card will digitize analog picture signal into compatible format.
May 28, 2008 | Sony Handycam CCD-TRV78E Camcorder
How do that the image is blask and white?
Dear Sasanka,
I think CCD-TR517 is more then 10 years old and it has hardware problem i.e capacitors in camera got weaker and need to be replaced all of them.
May 25, 2008 | Sony Handycam CCD-TR517 Camcorder
Sony Handycam CCD-TRV37 Camcorder Logo
505 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
