Question about Epson Stylus C60 InkJet Printer
Communication problem I had to purchase a new printer cable for my printer, it is a 25 pin cable with a usb into the computer. Now I recieve an error message "communication error" and I can not figure this issue out. Any suggestions would be appreciated! Thanks, M.
  • Anonymous Dec 13, 2007
    check all connections and make sure all devices are on. if power has turned off during printing cancel the print job. if error does not clear, see your printer documentation.
  • Bun1 Feb 25, 2008
    Prints about 6 lines and then stops. Everything is connected properly and I have uninstalled and reinstalled the printer. If I look at Properties it states a communication error. Also, there is a long list of dummy documents waiting to print which I keep cancelling but they keep reappearing.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Epson Master
  • 1,362 Answers
Are you saying that you have a parallel to a USB input !!!!!
Never seen or heard of one, that may be your problem USB goe to a USB input, Parrallel can go to a parrallel or to a network connection.
Posted on Oct 11, 2007
Where is the printer port on my acer aspire 7551-2961?I did not get an user guide and am a lost senior citizen trying to communicate with my grandchild.MCV
Most printers now use the USB port instead of the older parallel ports that has several input/out pins. Some printers (new-out-of-the-box) do not come with the USB cable, therefore purchase one for your printer if it requires a USB cable. The computer should have more than one USB ports to plug into.
Nov 01, 2010 | Computers & Internet
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
I just installed my designer software onto a new computer that doesn't have a 25 pin printer cable, however, I bought a usb/25 pin cable and have the dongle attached...but the software says the dongle...
Your software still is looking for the 25 printer pin connection from the motherboard. I don't know computer set up from an engineering concept, but I do know that the usb connection you purchased doesn't work with that software. You'll need to either get the new software or a used computer with the printer port hook up.
Nov 01, 2009 | Husqvarna Designer I
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Connecting printer
You can purchase an adapter "Parallel to USB" for printers to be used with printers.
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0489585&cs=04&c=us&l=en&dgc=SS&cid=30098&lid=674094
Hope this helps. Bud
Jan 09, 2009 | Xerox WorkCentre XD105F Laser Printer
USB to 25 pin printer
ok visit this site http://www.byterunner.com/byterunner/category=USB+to+Parallel+Adapters
Nov 22, 2008 | Toshiba Satellite M35X-S111 Notebook
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Epson Stylus C60 InkJet Printer Logo
291 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
