Question about Hitachi 55FX48B 55" Rear Projection Television
Hitachi 60ux58b projection tv
Had some power outtages and now can't get it to turn on. no red light power indicator. any suggestions. I hope it can be fixed??? help??
  • applebannana Aug 04, 2008
    I am having a problem similar, I was watching the tv and then it just turned off. I opened the back and dusted :) and then plugged it in. I watched the little green lights turn on and when the 5th light lit up the red (protect LCD) light flashed and then all others went off. Do you have any ideas? The fuse looks great (the wire is not busted).
    President:
  • 3,130 Answers
If there is no power indicator, you could have gotten lucky and only the main fuse insiude the set blew. You can unplug the TV set, take off the back of the TV. Then where the line cord comes out of the TV set and plugs into the wall, look where the line cord enters the set and look for a glass type cylinder fuse. If it is black, most likely there is a short inside the TV set. If it is not black, try replacing the fuse with ONLY the type that is stamped on the side of the fuse. If the set still does not work, or if the fuse blows again, you will need to have the set serviced by a pro. Good Luck
Posted on Aug 19, 2007
Hey did you fix if not i will buy your screen
Posted on Feb 10, 2008
My Hitachi 60UX58B 60 in. TV was on, popped, turned blanck and now won't turn on. Checked the fuses and everything looks fine. Any suggestions?
Youre in luck. This is a very common problem and an easy fix. Goto TvRepairKits.com to get the parts and repair instructions.
Feb 18, 2010 | Hitachi 60UX58B 60" Rear Projection...
I HAVE A HITACHI 60UX58B REAR PROJECTION TV. WE WERE WATCHING TV AND THE TV MADE A POP NOISE AND THE PICTURE WENT OUT. NOW THE RED POWER LIGHT WILL NOT COME ON.
Power board is dead,know how to solders?Replaced those capacitors that puff up or burst open.Or buy a whole refurbish power board at Shopjimmy.com,Ebay.com.
Jan 26, 2010 | Hitachi 60UX58B 60" Rear Projection...
TV popped and turned off and won't come back on
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jun 27, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
Tv will not power on
Hope this helps,
May 01, 2008 | Hitachi 50SBX78B 50" Rear Projection...
60ux58b hitachi
Hope this helps,
Apr 29, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 60UX58B Comes on then goes back off.....
Yes, i just answered a post to another problem simular to this, it is the POWER SUPPLY, it was blown either from an electric surge, caused by storms or ground faults, or it was shorted. you need to get a new one, have a professional install it for you.
Apr 22, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi model #60SBX78B
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
Jan 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
BLACK SCREEN WITH SOUND
Is the TV connected to cable? Is there a cable box? Is it connected to a satellite box? How is the signal connecting to the TV - the F connector, the red,white,yellow, red,white,,s-video or component RCA jacks? If you can see the onscreen menu then it usually indicates that the TV is working fine and the problem is with the signal into the TV.
Aug 19, 2007 | Hitachi 60UX58B 60" Rear Projection...
Wont power up
I have seen that symptom many times. Most likely, the little blue capacitor next to the horizontal output transistor has shorted and popped the main B+ fuse. This is very common in those Hitachi projection sets. These parts should be replaced by a tech familiar with Hitachi projection sets.
Aug 14, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
145 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
