Question about Samsung HP-R4252 42 in. Plasma HDTV
I have a Samsung HP-S4253X/XAA Plasma with coloration problems
My TV is about 15 months old and is now starting to show a bright purplish tint to high contrast images, i.e. faces, whites etc. Usually not all over the screen but only when in high contrast Blacks in background. Does anyone have any idea what might be causing this???? It seems to only do this when it has been on for an hour or so and the input source does not matter. Antenna, HDMI, or Component. Thanks,
    Novelist:
  • 192 Answers
The problem is normally called "Diffusion". It's the most common problem I come across on Plasma televisions. If this is your problem, then, the VSCAN and/or the VS must be adjusted (usually counter clockwise about 10 volts). The VSCAN is adjusted first and will remove most, if not all the diffusion. If you need a technician in your area, contact Samsung at: 1-800-samsung. If you like, respond to this post with a picture and we can analyze it further.
Posted on Aug 19, 2007
  • 81 Answers
Bad plasma pannel
SOURCE:
Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
Sep 13, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Color bleed thru problems
this set only has a 12 month parts and labor warranty so you need to call 1 800 samsung or the dealer you bought it from..the problem with adjusting the v_set and v_scan voltages is it may last for 6 months and then you would still need a new plasma panel..better to have a samsung authorized tech check it
Sep 18, 2007 | Samsung HP-S4253 Television
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Blue tint
This is usually caused by an over voltage on one of the panel voltages, if you open up the set and look at the panel you will find a sticker with the panel voltages on it, if you adjust the VS voltage down about 10 volts it will go away, if it doesn't the adjust the Vscan voltage down about 5-10 volt
Apr 11, 2007 | Samsung HP-P4271 42 in. HD-Ready Plasma...
Samsung HP-R4252 42 in. Plasma HDTV Logo
427 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
