The upper sprayer arm fell off on my Frigidaire model FDBB4365FC0. I am trying to replace, but don't know if I need a whole new arm or just the gaskets. Can anyone help
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Hello wladyka, that's a great question!
Normally, the spray arm would just screw into place on a Frigidaire dishwasher. If you continue to experience issues with the spray arm I would suggest consulting with a professional for further assistance. Hope this helps. -Matt
My upper sprayer arm also fell off. I can't figure out how to replace it.
I have the same problem and I am still working on it.
I'm having the same problem to
