Question about Krups ProAroma 453-71 Coffee Maker
Half a pot short of a good morning
The coffee maker makes about 2 cups, then quits. Occasionally, it will make a couple more cups a few minutes later. It is not plugged up...a water/vinegar cleaning mixture went through without a problem.
  • John Welch
    John Welch Mar 31, 2009
    same problem - it is the thermal overload switch in the bottom. it gets old and stops working smoothly (i think it is a bi-metalic contact switch of some sort), when the switch malfunctions the heat coil gets no power and cannot work properly and will work intermittintly or not at all.it is easy to fix but try finding the part! good luck.
Sounds like the thermal fuse (search this database under "fuse" and you'll find a discussion of it). I have yet to find the proper TORX security wrench, so I haven't been able to get to mine in order to try the things mentioned there, but I have a similar problem and what is said there makes sense.
Posted on Jun 19, 2008
SOURCE:
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
I made a normal pot of coffee this morning. The clean light came on, so I cleaned it. The coffee pot is only 2-3 months old. I know the process of cleaning it can take up to an hour. After about 30...
I think there is a real problem with the whole cleaning system with the Mr. Coffee Pot. I have one and after making only a few pots of coffee, the light starts blinking. I have cleaned it over and over and still get the same alert. My son had the same problem you have with his, it wouldn't finish the cleaning cycle. He'd had it awhile and ended up tossing it because it was beyond the warranty and store told him too bad. I've had other Mr Coffee makers and like them, but they didn't have the irritating "clean" alert OR the obnoxious BEEPING to let you know it's done brewing. If I knew this was going to be an issue - I would never have bought it. Why do they have to screw around with a good thing - more buttons and thing cycles to cause problems.
Sep 04, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
How to use coffee maker
This type of coffee maker is made to keep hot water always ready to make another pot.
Pour water in ( at least 4 cups)then turn it on with the pot installed to catch the water. It takes a few minutes to get it hot . You might hear it heating. I can with mine.OK after the heating sound goes away put some coffee in the filter and in stall the filter.Now, fill the pot again (at least 4 cups) and pour the water in and put the pot ready to catch the coffee.It makes the coffee fast because it already heated the water from the first time you poured it in.When finished with the coffee just turn off the burner only.These types are made to stay on 24 hours a day.
I just turn mine off and let it heat up the water in the morning.
Nov 04, 2009 | Bunn Pour-O-Matic VPR
My Survival Guide To The Dreaded Err2 Disaster
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Thank you, have a nice day.
Aug 30, 2009 | KitchenAid KCM511 Coffee Maker
Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Krups ProAroma 453-71 Coffee Maker Logo
223 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
