Question about Epson Stylus Photo R800 InkJet Printer
Ink warning light
Hi I am having trouble with my epson stylus r800 printer. The problem is the ink supply warning light was flashing red so I changed the cartridge that need changing and now it isn't flashing but just a constant red light and I can't print anything. The cartridge I used is from a different country than where I purchased the printer but it is exactly identical to the printer cartridges that are already there. Any help on this matter will be much appreciated. Thanks Viv
  • 2,985 Answers
PPut the machine to Carridge change and lift the troublesome one out and reinsert it. No Joy -try this If you have the original cartridge- prise out the chip and replace it to the new cart. The chip lifts out and there is a locator slot and hole to get it in right. Also The Epson utility is a useful tool to fix Epsons foibles
Posted on Aug 20, 2007
    Problem Solver:
  • 18 Answers
Often tho they seem the same the alingment of the nozzles dont match, so check alingment most printers offer you a programme that will do this for you...
Posted on Aug 19, 2007
The feed indicator light and ink light flash alternately (back and forth). the R800 won't print, allow cartridge tray to move, or feed paper.
Lights flashing alternately means that your printer's waste ink pad is saturated. It needs to be replaced and reset the counter. To reset the waste ink pad counter you will need a resetting program. You may download it by going to this link:
Aug 31, 2010 | Epson Stylus Photo R800 InkJet Printer
After changing the ink, the red light is still on.
epson stylus photo R200 printer the two red lights are flashing can get it to work help
Jul 18, 2010 | Epson Stylus Photo R200 InkJet Printer
Red Light for (ink) comes on.(Epson Photo R800)
Epson has a problem that if it stays for one month or more the ink dries and it wont print.
usually what i do is taking out the head and put it in some alcohol. for a day or two. the i blow dry it or leave it dry for two or three days.
take a straw and blow into the holes real hard.till it works . try it. it is not easy
Apr 12, 2010 | Epson Stylus Photo® R800 InkJet Printer
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson R800 The power light is solid green and the ink button is solid red. I cannot print anything because one or more of my cartridges are empty, but it won't allow me to use the Status Monitor to check...
Open your printer cover and press the ink button. The cartridge under the out of ink symbol is the empty one. The following URL has the details:
If you press the ink button again and another cartridge lines up with the out of ink symbol, record that. Repeat until the cartridge moves to the replace cartridge position. Buy all the ink you need before you attempt to replace any of the cartridges.
I hope this helps.
Nov 15, 2009 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus Photo R800 driver ran out of ink weeks ago. Today new ink cartridges arrived. Replaced all cartridges (even the ones that were ok) because the printer's low ink light would not go out until I...
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
Sep 22, 2009 | Epson Stylus Photo R800 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Trouble codes - red and green light flashing alternately
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. If you want to have a go at doing this yourself, the 820 service manual can be downloaded from here:
Jan 11, 2009 | Epson Stylus Photo 820 InkJet Printer
Epson R800 Red Color Problem
Actually magenta is the weakest compared to cyan and
yellow using even K3 inks. Now epson is releasing
K3 with vivid magenta ink. Using any color management
I have found it very difficult to reach a real red without
a lot of tweaking in my color profiles. Now it appears
that Epson sees the problem and is changing magenta
out for vivid magenta ink to solve the weak magenta.
Jul 17, 2008 | Epson Stylus Photo R220 InkJet Printer
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R800 InkJet Printer Logo
142 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
