Question about Dell Latitude C640 Notebook
While Playing the DVD
I have an Dell Latitude C640 laptop(configaration Intel Pentium 4 processor 1.9 G.Hz, 512 kb chache,512MB RAM and Combodrive(CD R/RW and DVD-ROM)) Detailes of the problem Now the problem is, when i play the DVD video for first time it will play properly for 30 min, after that the DVD video play will become slow(often struck up)and it wont play any DVD Video. Then if i shutdown the system for around 10 hrs DVD video start working properly for 30 min and again the same problem as i described. Except the DVD Video everthing is OK.
  • 63 Answers
You probably need to clean out the pc. Get rid of programs that are not needed or used. Do a "Disk Cleanup", Defrag until it takes only about 1-2 min to complete. Get an Anti-spyware/malware as well as an Anti-spyware program and run it once a week. You might want to also invest in more RAM. 512mb these days isnt much.
Posted on Aug 18, 2007
SOURCE:
Hi! pls. help me if there any Ram other than ddr 266 that compatible to my dell latitude c640 pls. i want to upgrade it into higshest
Go here and see your options:
http://www.crucial.com/store/listparts.aspx?model=Latitude%20C640%20Series&Cat=RAM
This site is your best choice for support, price and quality.
Aug 11, 2011 | Dell Latitude C640 Intel Pentium 4-M...
I have a mainboard of model D845GVAD2------------------------AAC18931-104. It has already intall the Intel celeron processor of 1.8GHz. Now I want to upgrade my processor. So what high frequency processor...
The Intel® Desktop Board D845GVAD2 supports a single Pentium® 4 processor with a system bus frequency of 400 MHz or 533 MHz, or a single Celeron® processor with a system bus frequency of 400 MHz.
So you can install upto 3.06 GHz 533 MHz(cache memory) processor and also update the ram 2 GB 400 mhz.
Dont install Prescott processor.
Hope it will help you.
Dec 31, 2010 | Intel Desktop Board D845GVAD2 Motherboard
My laptop has failed to start up. It gives me an error code 1000-0416. It's a Dell latitude D610. What steps should i take to fix this? Thank you.
hello, Plug your laptop to an external monitor and restart,maybe it is a VGA problem,if it does not start change the RAM,if it does not start again,then there is a problem with the motherboard
Nov 18, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
My dell latitude c510/c610 failing
Sounds like the fan may be failing and need replacement. On a system that age, it is debatable whether it is worth fixing.
You can boot to he resource cd and run fan diags is you want to try and confirm
Fans can be found on EBay
May 26, 2010 | Dell Latitude C640 Intel Pentium 4-M...
Dell Latitude 1.6 GHz/512/40GB-processor speed seems to be stuck at 221 mhz regardless of what app I am running. Is there a way to adjust the speed of the processor? Or is the processor bad?
The processor is throttled by a process called speed step. This slows the CPU to save power. The same process is used when the processor overheats, and the system throttles to manage the heat production.
So the heatsink and cooling fan should be replaced as the first step in trying to resolve the process.
Jan 11, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
I want to upgrade my hpdv1000 pentium M processor whats the maximum upgrade allowed for this? i have upgraded it to 2gb ram from 512mb and 250gb hd from 60gb and its doin fine.
You should be able to upgrade the CPU, since it seems that the DV1000's motherboard uses a socket CPU design. But, obviously, HP would rather have you choose the CPU that you want from the beginning and stick with it.
The first thing to do is to check HP website to see what other configurations were/are sold for your model. If they sell it with faster CPUs then you can upgrade to one of them...
PLEASE NOTE:
In order for a particular processor to be compatible with a particular laptop:
(1) the processor must be physically compatible with the laptop socket, in your case I thing you have a Soket 479 processor
(2) the laptop chipset must support the processor.
(3) the chipset front side bus speed must match the processor front side bus speed, in your case 400Mhz.
(4) the laptop BIOS must support the processor.
So I listed here processors with FSB at 400Mhz, I gues that DV1000 as a 855GM Motherboard that supports only 400Mhz with Socket 479
Pentium M
Banias
Pentium M 1.3 1300 1024 400
Pentium M 1.4 1400 1024 400
Pentium M 1.5 1500 1024 400
Pentium M 1.6 1600 1024 400
Pentium M 1.7 1700 1024 400
Dothan
Pentium M 710 1400 2048 400
Pentium M 715 1500 2048 400
Pentium M 725 1600 2048 400
Pentium M 735 1700 2048 400
Pentium M 745 1800 2048 400
Pentium M 755 2000 2048 400
Pentium M 765 2100 2048 400
Celeron M
Banias-512
Celeron M 310 1200 512 400
Celeron M 320 1300 512 400
Celeron M 330 1400 512 400
Celeron M 340 1500 512 400
Dothan-512
Celeron 205 1200 512 400
Dothan-1024
Celeron M 350 1300 1024 400
Celeron M 360 1400 1024 400
Celeron M 370 1500 1024 400
Celeron M 380 1600 1024 400
Celeron M 390 1700 1024 400
Best Regards
Jun 23, 2009 | HP Pavilion dv1000 Notebook
Dvd decoder error
Go to the Dell support site and enter your computer model number under the drivers and software section. Download the latest driver for the model of DVD player in your system.
Jun 01, 2009 | Dell Latitude C640 Intel Pentium 4-M...
Disable system bios
never disable system bios, i dont even know if there is a way to do that. the bios exists to provide software for your motherboard to work correctly. i suggest you download from another machine your updated bios version from dell.com and put it on a thumbdrive, then boot into safemode and load the file. it should correct any issues you have. there is a possibility that you may have an issue with your new ram. some machines are pretty specific to which types they will take. so get that information from the dell.com site when you get your bios update.
good luck!
ruben
Mar 28, 2009 | Dell Latitude C640 Intel Pentium 4-M...
Dell Latitude C640 Notebook Logo
76 people viewed this question
Ekse
Clive
Clive
