Question about Canon Pixma MP500 All-In-One InkJet Printer
Error code 5010
I found a similar thread regarding w/ my problem however it won't work out (removing the plug open it after 10 minutes). The other alternative is somewhat impossible for me (location of where I bought). Any other possible solution that you could share. Tnx!
  • 4 more comments
  • fancyletters Aug 17, 2008
    keep getting error message 5010
  • Lydia Oct 18, 2008
    Canon MP810. The error code 5010 appeared on the lcd screen and stopped the procedure of printing in the middle.
    After turning the pixma off, I turned it on and the message U13 about not being able to detect the black ink appears.
  • Anonymous Nov 05, 2008
    ERROR5010
  • Anonymous Jan 11, 2009
    Mon imprimante Canon Pixma MP500 ne respecte plus les caractères d'imprimerie du ducument
  • jk89836 Jan 14, 2009
    Computer displays Error 5010 message. Looking for a solution how to fix?
  • Anonymous Jan 23, 2009
    nu stiu *** sa rezolv proplema va rug sa ma ajutati
In my case, I have that 5010 error as well and we called in the technician to solve our problem under the 2 year warranty that was given to us. Apparently, the motherboard has issues and had to be replaced.
Posted on Aug 20, 2007
Uninstall&reinstall mp830
Posted on Jan 26, 2009
I pressed the reset button - as recommended for the cartridge to be detected and ..miracle: the cartridge problem vanished as well as the error 5010 message!!!!!!!! I printed a document with no problem... For how long this will be ok though I cannot tell..
Posted on Oct 18, 2008
    Problem Solver:
  • 25 Answers
It can be simply a disconnected ribbon coming from the scanner. It is easily disconnected and it is sufficient to connect again by opening the right side of the printer (three screws) and carefully puting it again in place without diconnecting it again (very easy!!)
Posted on Jan 28, 2009
Error code 40, found problem, still wont start
you can disconnect the battery to clear the codes. If I remember correctly the code 40 is indicating an open injector circuit. You might want to check that area as well as the service manual for more detail
Nov 15, 2011 | Yamaha YZF-R6 Motorcycles
Canon pixma MP600, error code 5010, what does it mean ? Can not turn the printer on for any other purpose, no scanning, copying or printing.
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Nov 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Sep 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
Jul 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
Sep 02, 2017 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5010
Canon Tech Support directed this solution and it worked. It is similar for all electronic devices like Routers also. These devices need their "electrical brains" refreshed occasionally. 1. Turn off the printer (MP 830) or other 2. Disconnect the printer from the power outlet (totally unplug the printer) 3. Wait for 1 minute - not less than that. 4. Plug the printer back in to the electrical outlet. 5. Turn the printer on
Apr 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code 5010
I got the error code 5010 today (scanner lock switch). I called Canon. The printer's electrical circuitry (brain) needs to be refreshed. This is similar to wireless routers and other devices. They directed me as follows: 1. power OFF the printer 2. Unplug the printer's power cord from the electrical source. 3. Wait AT LEAST 1 minute - no less than 1 minute. 4. After 1 minute, plug-in the printer to the electrical source. Turn on the printer - wait for it to warm up as usual and it should be ok. Mine worked perfectly after the above steps. - Hope this helps.
Jan 12, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
2,586 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
