Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hp Printer Dos't Not Print
I have installed Hp deskjet Printer 3900 Series,all the catridge having a full Ink. but That printer does not printing and do not accept a paper Why..?
The Sensores on your printer are not recognising the paper, either the sensor has dirt on it or jiggle sensor a little and this should solve your problem if not let me know.
Posted on Aug 18, 2007
SOURCE:
Ink levels lights flashing but ink is full
Might be cartridges are refilled.
You may got doubt why its not measuring the ink levels?. When printer found new catridge(printer/system based on design) will treats that new cartridge installed & estimated level will display fully.After couple of print outs printer/system will displays estimated ink levels depend upon the ink usage. But there is no mechanical ink level sensors or any other device for mesuaring the levels..Once the ink level trated empty you need to replace new cartridge straight away,if you refilled the same catridge it wont measure the levels, because of the cartridge data code already stored in printer. ..
Nov 02, 2011 | HP DeskJet F4280 All In One Printer InkJet
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
Printer has been idle for several weeks.When I came to use it the printing is broken and faded looking.How do I clean the cartridges?
HP Deskjet 5550 Printer.
The deskjet printers should not be kept idle.
At least once in two or three days, you can take one page print out.
This has to be done, otherwise, the inks both Black and colour will get frozened and sometimes it will become dry at the catridge mouth.
Black Ink is 56 and Colour is 57.
Solution :
01. Manually remove both catridges from the printer carefully.
02. Shake the catridges with full force pointing towards ground. You can find out now, that ink is coming out from the catridges which was frozen or dried up.
03. Clean the cartridge drive with a nice cloth and cleaning liquid.
04. Re install both catridges and take a test print out.
05. Recommended to have a service contract with local HP Authroized printer vendor to have a regular maintenance at least once in a month.
Jul 21, 2009 | HP DeskJet 5550 InkJet Printer
HP Deskjet F4288
no problem
;just take out the catriges and clean them
;after that plug ou the power cable
:after 30 seconds plug it back in
:nw put in the catriges
:ur problem will get resolved
Jul 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
HP deskjet F4140 Error light on & I can"t print
please reset your printer. turn off your printer, leave it for 30 sec and turn it on again....
If you still have problem try to re install the catridges again, follow below instruction
http://etech.maiila.com/hp-deskjet-f4140-all-in-one-printer-catridges-installation
Good Luck
Nov 01, 2008 | HP DeskJet F380 All-In-One Printer
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
134 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
