Question about RCA P52928 52" Rear Projection Television
Non Responsive 35" RCA
When the tv is turned on, the volume is way up and the controls on the tv or remotes (I have tried several which work) are non reponsive. The channel can be changed at the tv control panel only. Please Help.
    President:
  • 3,130 Answers
You are going to have to check all of the small tact switches behind the push buttons in the front of the TV set. In the past, someone may have cleaned the picture tube and the liquid dripped down onto the switches and corroded them, or one is stuck closed or the remote sensor is bad. The best way to test this would be to replace the entire switch panel in the front of the TV set. Good Luck
Posted on Aug 19, 2007
SOURCE:
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Can I have the TV code for HITEKER TV model 1931-31
Hi Ralph!
I'd try using remote code 0060. I pulled this information from:
Universal Electronics Remote Control Support
Hope this helps!
Mar 01, 2015 | Televison & Video
TV comes on but non-responsive otherwise
I would purchase a replacement. The damage a surge can do is usually not economic to repair.
Sep 04, 2014 | Panasonic TH-58PZ800U 58 in. HD-Ready...
Non responsive buttons
You have to open up the remote. The underside of each button has a black disk. Clean each button with a pencil eraser. Then look at the circuit board. Where each of the black discs would make contact (looks like two "E"s facing each other) clean each of those with the eraser. But the remote back together and all the buttons will be responsive.
Jan 17, 2014 | Universal Remote Control Universal Remote...
My RCA 46la45rq tv remote AND side buttons stopped working
The panel control circuit inside should be checked. Contact any experienced service technician.
Nov 27, 2012 | RCA 46 46LA45RQ LCD TV
Ct90302, not working, what to check?
NON RESPONSIVE, CHANGED BATTERIES. CANNOT TURN OFF AND ON.
Oct 15, 2012 | Toshiba Ct-90302 Remote Control
REMOTE CONTROL CAME WITH THE DTA800. PUT IN ALL
I CALLED THERE 800 NO. THERE ARE ONLY 4 CODES FOR MY TV IF NON WILL WORK IT. CAN'T BE DONE.HAVE TO USE BOTH REMOTES OK THANK YOU
Jan 08, 2010 | RCA Televison & Video
VOLUME CONTROLS ARE NOT WORKING.
does your laptop have its own volume control turned down or muted, This is a common error, Post back if no help please.
Jan 04, 2010 | Logitech X-530 Computer Speakers
Channel locked
with the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
Apr 14, 2007 | RCA 27F530T 27" TV
RCA P52928 52" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
