Question about AOC LM 720 17" Flat Panel LCD Monitor
Monitor screen blank and LED orange light flashing
Monitor screen is suddently blank and LED orange light( next to poser switch)is flashing while i am using it. I unpugged it and i reset power. Still orange light is flashing. Can you help how do i fix problem. thanks
I think you should try clean the cmos first... its not a monitor problem but for the system.
Posted on Aug 20, 2007
  • 63 Answers
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
SOURCE:
The screen goes blank after 1 second display, flicks back again to the display for 1 second and back to blank, this goes on non stop. The little led next to the on/off button goes from green to yellow...
pandres, Your monitor will need troubleshooting to find out reason why the 2 "cold-cathode-fluorescent-lamps" fail to remain lighted. They provide "white light" so you can see what is on the lcd panel. Connect a "known good" monitor to your pc to prove monitor is bad. If pc is ok, then your monitor will need repair. This type problem not new and is very common for all brands of ccfl back-lit lcd monitors. Watch some video clips at YOUTUBE that show disassembly and repair of ccfl lcd monitors. Read fixya profiles of "budmrtn" buddymc" "12fixlouie" for more information. 12fixlouie
Sep 08, 2010 | Neovo S 19 19 in. Flat Panel LCD Monitor
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Nintendo DS won't power-up
It sounds like a faulty battery. As it is under 1 year old, it is still under warranty. Return it to the origional place of purcase, who will either fix or replace it.
Aug 19, 2009 | Nintendo DS Lite Console
Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Sep 14, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Toshiba tp50f60
f your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset. To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Dec 04, 2007 | Televison & Video
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
AOC LM 720 17" Flat Panel LCD Monitor Logo
1,344 people viewed this question
Top AOC Computers & Internet Experts
Ekse
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
