Sounds like a bad battery. Try charging overnight with a 1 or 2 amp charger.
If this doesn't help then go to the dealer and ask for the stock plugs for your bike. Check for spark on each of the new plugs then install the plugs.
Remove the carbs , dissemble it and clean the varnish out. Remove the petcock, ( gas valve ),water trap and clean it out. Next let one cup of gas flow into a container. Any water or rust in the bottom of the container? If any rust was in the water trap or the container then purchase an inline fuel filter to eliminate the rust getting into the carb.
If cleaning the carb yourself does not do the trick then take it to the dealer and have them clean it and install a carb kit. This should eliminate the carb as a problem. Get a new air filter and install it.
Now you have spark, gas and air. If it still will not start it is likely that you need new crank seals. On a bike that old you may well need new crank bearings as well.
I'm having the same issue, bike won't start, lights are barely coming on when i turn the key to "on".
Where is exactly is the battery?
I can't find it, i figured it'd be under the seat, but it's not there..
Replaced battery and bike still wont start
Once bike starts starter continues to turn over
