Question about Kaser Corporation Mambo Mano Digital Media Player
Connectivity to the computer
Once i connect the player to the computer the computer does not show if the device is there
  • Anonymous Nov 09, 2007
    I also have the same problem. It charges but i can't access it.
  • Anonymous May 29, 2008
    I AM USEING WINDOWS XP PRO AND I HAVE TRYED PLUGGING THE MP3 PLAYER INTO THE PORT AND IT SHOOTS ME TO THE MEDIEA PLAYER,AND DOUSE NOT SHOW ME THE REMOVEIBLE DISK E:/ PART THAT IS SUPOST TO POP UP FOR ME???? I NEED STEP BY STEP INSTRUCTION TO GET THIS THING TO WORK.... THANK YOU SO MUCH FOR YOUR HELP.
    Problem Solver:
  • 15 Answers
Looks like media player is set to automaticly sync. Try turning it off and just double clicking "my computer". It should show up there and be ready to drag and drop. Just right click on the files first, as this player will only take mp3 or wav!
Posted on Jul 14, 2008
I tried with a different cable that did not come with the device, and it showed up with it. If you have another cable that is like that one, try it out.
Posted on Jun 07, 2008
SOURCE:
How can i delete all files on my mp3 player using the computer
Your MP3 player can be connected to a computer through USB. You need to have the proper USB cable. Once connected, if your computer recognizes the device, tt should show as a Removable Drive and you can open folders just like any computer Herd Drvie.
If it is not recognized, take note that some players might need a driver for your specific operating system. In that case, please reformulate your queston, specifyiny your player ans computer system.
Oct 22, 2015 | Audio Players & Recorders
The device can not be detected in my computer
Hi there.... You can try other computer if they can detect the Sony Walkman that you have, if not being detected, have the device physically check.... if being detected by other computer, try updating the driver or software for that Sony device..
Thank For Using Fixya
Jun 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
I can't get the computer to recognize that the mp3 player is connected through the cord. I also can't turn it on nor can I move songs from the computer to the player or vice versa.
Try this:
Find your Device manager located in System then chose harware then chose device manager,
With the device now, connect it to your computer and you should see the device manager list refresh. In the list you should see your mp3 player show up. if theres an issue a Yellow dot will show up next to it. simply reclick on the device and either update it or if that doesnt work, right click and uninstall the device then reinstall the device.
it might auto detect the device once uninstalled. Goodluck
Dec 19, 2010 | Computers & Internet
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Feb 16, 2009 | Sony Network Walkman NW-E005 MP3 Player
The device does not show under My Computer when plugged in
You will have to go to the Manufacturers Website and Download Updated Drivers for your PC. That should take care of the Problem.
Jan 08, 2009 | SanDisk Sansa e250 MP3 Player
Mp3 froze
From the Sansa FAQ page at http://www.sansa.com/support/sansa_e200/faqs
09. When I turn on my e200, nothing shows but the blue ring is on, what do I need to do?
Applies to the following Operating Systems:
  1. Windows XP, Vista
The player might have a power glitch. As a result, it does not turn on and is not being detected by the computer.
STEP1 - Reset the player
  1. Hold down the Power button for 20 seconds, then release.
  2. Run the hotfix.
STEP2 - Connect the player to the computer
  1. Connect the device to the computer
  2. Once the device responds, disconnect, and turn it on.
Jan 04, 2009 | SanDisk Sansa e250 MP3 Player
Nothing but light
okay to fix this problem you need to do this steps..
1.) Try to press and hold the PLAY button while connecting it to your computer.
(This will allow the device to connect to the computer in safemode.)
2.) Once connecting to the computer is successful, download the upgrade firmware to the device, and follow the upgrade steps.
Upgrade firmware can be found at the link provided below:
http://www.rca.com/digitalaudiodownloads
if you have any more questions feel free to email me @
[email protected]
Nov 19, 2008 | RCA TH1101 MP3 Player
Sansa Connect
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Jun 17, 2008 | SanDisk Sansa Connect MP3 Player
Does not recognize
The dinging sound is the USB port telling Windows that a device is connected, and does not necessarily mean that Windows recognizes a device.
Are you using Windows Media Player 10 or higher?
May 21, 2008 | SanDisk Sansa e250 MP3 Player
I have some china made mp3
Make sure that you have installed the software the the mp3 player came with and that you have powered on the mp3 player once it is connected. If you want the Sansa e250 to show up in "My Computer" under removable devices, go to the main menu of the player software and go to Settings/USB Modes/ and change the mode to MSC (Mass Storage Class). Hope that helps.
Aug 17, 2007 | SanDisk Sansa e250 MP3 Player
Kaser Corporation Mambo Mano Digital Media Player Logo
42 people viewed this question
Top Kaser Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Kaser Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
