Question about Siemens SK65
No sound for incoming calls on SK65
Help -- frustrating problem. When the phone receives calls it does not make a ringing noise, regardless of the tone/volume/profile settings etc. This is a recent event, has worked well until recently. Still makes sound for sms messages received. There is an icon on the front "ringtone only if the caller is stored in the phonebook". I don't seem to be able to turn this off, and there is no reference to it in the manual. Not sure if this is related to the problem. I have been through the paper manual and the latest online manual but cannot find any reference to this problem,
  • 3 more comments
  • Maceboy Aug 19, 2007
    I fiddling around to try and fix it I have also duplicated the address book. Is there an easy way to delete the 'second copy' without killing the first ??
  • Maceboy Aug 27, 2007
    I've tried the settings/ringtones/ringer setting but still does not sound for incoming calls. (sounds for SMS OK)
    So icon shows, ringer is turned on, but still no sound.
    By stored information do you mean phone numbers ?? That's all we really use the ohone for.
  • Maceboy Sep 04, 2007
    Hi there -- I still don't have a workable solution to the problem of no incoming sound. I've done what you suggest.
  • Maceboy Sep 06, 2007
    GREAT NEWS !!! I have found the solution to this all by myself.
    In desperation at lack of progress from suggested solutions I systematically fiddled with most areas of the phone. In doing so I found that the call screening was activated (which apparently generated the icon mentioned in my origianl post and stopped the phone from ringing.) I turned the call screening off and HEY PRESTO and as we say in Oz the bloody thing worked!! IIcon also disappeared). So in this case Fixya didn't get there, but hopefully you can use this solution for other customers should that arise.
    Sergeant:
  • 279 Answers
You've tried the Master Reset by typing *#9999#? What did the phone do when you tried this, if anything?
Posted on Sep 04, 2007
    Novelist:
    Scholar:
  • 114 Answers
Go to Settings -> Ringtones ->Ringer Setting and you'll find an actual On/Off option, this option literally terns all ring-tones on and off, the fact that you are seeing the "ringtone only if the caller is stored in the phonebook" icon suggests that you (or someone playing with your phone) have accidentally turned the ringer off. As to the question of deleting duplicated address book entries, if you have copied your SIM in to the Phone's phonebook you can simply delete the one phonebook using the delete phonebook option (backup using SmartSync first). However if you have copied all entries in to the same book you will need to pick through them manually. Message back if this doesn't help.
Posted on Aug 26, 2007
  • 3 more comments
  • Nicholas Wilson
    Nicholas Wilson Aug 27, 2007
    Change the default phonebook, it sounds like you may have set-up a phonebook and/or group with custom rules that may well be empty. Backup your phonebooks using the SmartSync program for your PC that came with the phone, once that's done try deleting all phonebooks and groups except the SIM card, you can do this from the phonebook's options menu.
    Also there is a firmware (Operating System) update available for this phone but it's not listed on www.benq.co.uk/support/downloads/downloads.cfm?product=1078 that would suggest that either the SmartSync program includes a firmware updater or you just need to download and run the SmartSync update from that page to install it.
  • Nicholas Wilson
    Nicholas Wilson Sep 04, 2007
    if you haven't already done so backup your phone using SmartSync and then from the phone settings menu select Master Reset, you can also run a Master Reset by typing *#9999# and pressing dial from the home screen (this will not effect the SIM or network) then restore your data using SmartSync.
  • Nicholas Wilson
    Nicholas Wilson Sep 05, 2007
    Dyllan, Master Reset by typing *#9999# and pressing dial is the alternative Master Reset method from this phones own manualhttp://www.sk65.info/Manual.1209.0.html?...
  • Nicholas Wilson
    You can also download the manual fromhttp://www.phonedog.com/content/loadreso...
  • Nicholas Wilson
    Nicholas Wilson Sep 06, 2007
    Thanks for letting us know how you solved it, that's worth keeping in mind. :)
    Genius:
  • 1,153 Answers
Is the ringer off? Can reset but you will loose stored info.
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
My phone makes the proper sounds to notify text messages and other alerts, but does NOT make any noise or vibrate upon receiving an incoming call. It appears to be set up to ring, but it does not!!!Can you...
click the volume button on the side of the phone then use the touch screen to slide the reciever slider to your preferred level then test it by calling.
Feb 09, 2010 | Palm Treo Pro Smartphone
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
Can't receive incoming calls
same here... I unlock it but it doesn't received call
Aug 16, 2008 | Motorola Mobility A1200
Verizon v325i does not ring with incoming calls
are you sure you don't just have the volume turned all the way down?
Oct 15, 2007 | Samsung SGH-p207
No sound when phone rings
Look at the ring volume. Make sure it's not at zero. Let me know if that works.
Jul 28, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
292 people viewed this question
Top Siemens Cell Phones Experts
Stormi  Paulk
Stormi Paulk
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
