Question about Pentax Optio S40 Digital Camera
Card problems what kind of card and how to work it
    President:
  • 1,114 Answers
You can download the manual from the link below: http://www.pentaximaging.com/files/manual/OptioS40%20Web.pdf The camera uses an SD card or internal memory, check the manual for how to format the card for use. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 18, 2007
SOURCE:
I have using windows 7,installed phillips 713x tuner card but there is some problem,that the picture is cleared but there is no sound...when i use it on win xp there will be everything alright.kindly tell...
Hi! Sorry, give it up, there is no one correct driver for you card. I have the same and made a research around 4 months and no one driver worked correct. I made modification to the drivers and try a lot of programming but no one driver never worked.
Dec 26, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
My 6300 restarts automatically when i insert any memory card why?
hi
there are some phone that will restart when memory card is inserted automatically for first time. but make sure that your phone will support the memory card that u use. if still problem arises kindly try your memory card in other phone if it works properly means the fault is in your mobile. kindly format the phone and try it. this will fix your problem..
thank you
Dec 19, 2010 | Nokia 6300 Cellular Phone
Memory card not working
hi
after inserting a memory card kindly restart your phone. make sure that your mobile willl support the memory cart tat you use. if so try it by restarting your mobile. if still same problem in memory card means try your memory card in other phones. if memory card works in other phone means there is some software problems in your phone. kindly ask your service men. if memory card is not working in other phone means then there must be fault in your memory card..kindly try it
thank you
Dec 19, 2010 | Samsung SGH i780 - Microsoft Windows...
What kinds of AGP CARD compani? What kinds of AGP
in case you have problem with your card
reinstall it or replace it
you can not fix it
Dec 05, 2010 | Palit Microsystems GeForce FX5500, (256...
My xp network card is not working some reason plz
There can be a problem with the local area connection, the driver, or it's just the network card that it doesn't work, for this i'll need to see what kind of windows do you have and try to disable and re-enable the local area connection (LAN).
After you do that try to see if it works, if it doesn't try to uninstall the card and re-install it, but to give you the instructions i'll need to know what kind of windows do you have...
Apr 27, 2010 | HP Compaq Presario C700T
My phone can't read memory cards
hi your phone is compatable with on certain kinds of memory cards and will not work with every other card available in the market. Kindly check your phones user manual and see what kind of card is compatiable with your phone. If even this doesnt work then i think your phones memory slot isnt working and u need to get it checked with an authorised dealer
Jul 05, 2009 | SanDisk 1GB microSD Memory Card
NO memory card Problem - Powershot 550
More likely one of the spring contacts in the camera that connect to the SD card has become weak causing the problem.
Mar 17, 2017 | Canon PowerShot A75 Digital Camera
Memory card error in 8GB card
Try to re-insert the card. If that doesn't help try to reformat it/delete all its contents. Also check in the manual what kinds of cards does the camera generally work with (although i doubt that is the problem).
Dec 23, 2008 | Canon PowerShot S2 IS Digital Camera
Olympus C-750 Trouble formatting card
have u tried to format the card on the computer??? try to format in a card reader.... and after on the camera. if that doesn´t work... could be the kind of card, there are diferent kinds of xD cards. good luck
Apr 02, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Pentax Optio S40 Digital Camera Logo
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
