Question about Dell OptiPlex GX260 PC Desktop
GX260 DOESNT BOOT
Have a Dell GX260 which struggles booting up each time it's turned off. it restarts many times it soudnes long beep and it some time boot . If anyone knows what the potential problem may be, let me know. Thanks!
  • 2 more comments
  • Anonymous Nov 29, 2007
    Hello i am ahving the same issue but my config is A-Green B-Green
    C-Green D-Yellow. what could this be we have a fuji specialist in house and he seems to think that the motherboard is bad. Just wondering what the Post D yellow would be.
  • MsTiki Dec 01, 2007
    I have kinda the same issue. I have a Dell Dimension 4700. It boots, but the monitor doesnt. I get 6 beeps like 1234pause56. Then the AC lights are green and the BD lights are yellow. Can anyone help me figure this out. I have tried cleaning and reseating the memory and I have replaced the video card, and still the issue persist.
    Thanks for the help in advance
  • rstan22 Sep 07, 2008
    Yes I have the same problem
  • nguks0 Nov 27, 2008
    The CMOS battery is dead and the system left untouched for few months. A long "Grock" sound is heard while the power is turned on. It can't boot thus I have to switch off the power after every trial. the machine is more than 5 years old and is no more under Dell warranty. Can anybody help please.
    From nguks
    Email: [email protected]
    Problem Solver:
  • 15 Answers
I think you should have to change your memory inside of your system. The long beep shows there is something wrong with your memory. If you have 2 memory slots on your mother boards. Please get another idle one to make a try.
Posted on Aug 19, 2007
    Scholar:
  • 181 Answers
Wait! first things first.There are 4 post lights in the back of the system. These are alternately yellow or green, depending on what area of the post it's in. If the system fails it's post routine at any time, the lights stop moving, giving a clue as to what the problem is. i.e., they could be Green green green yellow, or any combo of colors. if you will forward what color config it's hanging at, we will have a good stat point. Also, did you install any new devices prior to the problem starting? Good luck Harvester3
Posted on Aug 18, 2007
  • Anonymous Aug 18, 2007
    the cmos battery will be bad only if the system loses it's day and date settings every time it's turned off. I wouldn't replace the cmos battery unless necessary, as you will then need to re-set the cmos settings, which for inexperienced persons can be a bit troublesome.
    Thanks
    Novelist:
  • 231 Answers
Other things to try, 1 check the video card is not loose and monitor cable not loose 2 Change RAM into different positions. no3 into no1, then no2 into no1, this will make sure Ram is not faulty. PC always boots from no1 dimm RAM slot.
  • 24 Answers
Potential Problems : 1. RAM loose in the slot. Take it out, clean the contacts and reinstall 2. CMOS Battery ( Most probably Battery number is CR 2032 ), just replace it by a new one. 3. Faulty SMPS : Change / get it repaired. Good Luck, Rajesh
  • 24 Answers
You may also want to try run recovery console or a repair install. Note: always performe a backup before running any of these
SOURCE:
My pc doesnt load every time I want to turn after i boot the power and press 1st, 2nd, 3rd and 4th boot... in the screen I can see Dell is loading but doesnt move, i try to press F12 for boot and the...
Are you Sure that the computer model is Dell Optiplex GX260? Because looking at the manual diagnostic lights are found at the back. and the fault can be determine If the ABCD lights are yellow or green. But None the less 2/3 Depicts a hard drive problem while 3/4 depicts a memory issue.
Hard drive Issue:
1. Disconnect all non essential cables at the back of the computer. Leave only the mouse, monitor and keyboard. See if it boots up normally
2. If it boot up fine. try plugging one peripheral at a time until you find which peripheral causes the computer not to POST (Power on Self Test)
3. If you still getting problems, Follow these steps
4. To access the BIOS you must tap F2 or delete key upon turning the computer on
5. Try to look for the Hard drive if it is detected by BIOS if not got to step 9
6. Look for Boot Sequence or anything that is associated Boot
7. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
8. Save the changes and Restart
9. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
10. If Step 9 did not work I think you need to replace the Hard drive
Memory Issue:
1. Open the chassis of the computer
2. Try taking out all memory modules
3. Rub the metal contacts of all memory with a pencil eraser
4. If more than one memory. Put one memory first and turn the computer on. If it turned on add another memory and turn the computer on. Repeat these steps until you determine which memory is faulty or all memory module contacts needs cleaning
Jun 16, 2011 | Dell OptiPlex GX260 PC Desktop
My motherboard is dell GX260 when I trun on my computer it make 6 beeps what problem has my motherboar?
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
note.gif NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
Oct 28, 2010 | Dell OptiPlex GX260 PC Desktop
No display and can not boot but gives 6 beeps when switched onthe first four are continuous and then two
1.power supply
2.memory cards
at last mother board need changing !
hope it will help
May 20, 2010 | Dell OptiPlex GX260 PC Desktop
Can not boot dell poweredge from usb cd
try turning usb support on in the bios,if this doesnt work try reseting your bios this should return it to default,hit f2 as it restarts when you are in. hit alt e alt f it should beep everytime you do this,what this basically does is clears nvram, go to boot devices and see what you have available,exit and retry your boot device
Mar 23, 2009 | Dell PowerEdge 2650 Server
Dell PC Desktop Optiplex GX260 Doesn't boot
Open up the case and remove any add in cards and memory modules. Try to start up by adding these back one at a time until the unit stops booting normally. The light combination is not one recognised in the user manual so I am guessing you have a non-descript fault with one of your components. Be careful when you open the case as to not disturb the ribbon to the motherboard which controls the power, I have had a very long experience trying to get one of these reconnected!
Dec 15, 2008 | Dell OptiPlex GX260 PC Desktop
Cannot install vista on my dell optiplex gx260
have you set the boot priority to CD?
Also check whether this disc is supported in your drive.(check if the cd opens normally in windows)
Dec 02, 2007 | Dell OptiPlex GX260 PC Desktop
DELL GX260 bootup problem
To start with I would run FDSIK from a DOS boot disk and delete the partitions on the hard drive. Then reload the operating system. There is no telling what has been loaded on the system. After the reload the DELL should boot normally.
BPCS
Nov 15, 2007 | Dell OptiPlex GX260 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Dell GX260
can you be more specific when describing the computer 'struggling to restart'? Does it beep? Does it take several attempts to restart?
Aug 09, 2006 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
475 people viewed this question
Ekse
Clive
Clive
